Question about Robertshaw RS2110 24-Volt AC 1 Heat / 1 Cool Digital Non-Programable T
How to replace a robertshaw rs2110 termostat
How to wires
RobertShaw RS2110 seies: Had a power surge yesterday and now thermostat won't cool. Changed the batteries, turned fuse off then on which I know doesn't cut total power. 81 deg in here.
Power surges well known for damaging the control boards of any electronic device, yours may have been partially fried. I woild get a repairmant to check the thing before you lose the contents, see about the liability of the power company for damage
GOOD LUCK
Jul 06, 2015 | Refrigerators
HOW TO TROUBLESHOOT ROBERTSHAW GAS VALVE
check the pressure switch if voltage to both sides its ok then check the gas valve to see if voltage at brown and yellow wires
Oct 14, 2014 | Honeywell Robertshaw Grayson Gas Valve Lp...
How to install maple chase 9600 thermostat
The manual is very specific.  http://www.icca.invensys.com/manuals/robertshaw/110-653B.pdf    The Robertshaw 9600 is the same unit. The terminals marked RH, RC, W, Y, G are where you put the wires, just loosen the set screws with a small flat head screwdriver, insert the bare wire into the hole and tighten the screw. Leave the jumper between RH and RC for most installations. The red wire goes to the RH. Please come back and comment if you need more specific help. Good luck
Jan 08, 2010 | Heating & Cooling
I have a raypak heater with robertshaw 7000 gas
Remove the wires from the gas valve and call for it to light. While it is trying to light, take a voltage reading on the wires that go to the valve. If it is sending voltage to the valve and it won't energize the valve then the valve is defective. Just make sure that the valve is being told to come on. It could just be a limit switch. Double check the manual reset limits also before doing the vavle check. Hope this helps.
Mar 21, 2009 | Water Heaters
Wiring Amana Heat pump to inside unit and 9520 robertshaw
colors can vary. you should be able to locate a wiring diagram inside the airhandler and out door unit. you will have to remove the panels. generally though Green is fan RED is power WHITE is reversing valve Blue is common YELLOW is the contactor (usually have to jump w and y terminals at robertshaw tstats. PLEASE DOUBLE CHECK AT SYSTEM DIAGRAMS!!
Apr 20, 2008 | Amana PTH123B25AJ Heat Pump Air...
Robertshaw RS2110 24-Volt AC 1 Heat / 1 Cool Digital Non-Programable T Logo
Top Robertshaw Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Robertshaw Heating and Cooling Expert? Answer questions, earn points and help others
