Question about bitcount Cleartune - Chromatic Tuner
The needle won't move when tuning
The tuner does not recognize
Windows 8 is not compatible with my tv tuner
No surprise there then. See if your TV Tuner manufacturer has an updated driver by visiting their web site.
Feb 09, 2014 | Toshiba Computers & Internet
Why my internal tv tuner is not working in window 7
First thing you need to do is to check the brand and model of your internal TV tuner.
You can do this by knowing the motherboard you have or you can try to check under device manager.
There is a possibility that the TV Tuner you have is not compatible with Windows 7 or it doesn't recognize a correct driver for your TV Tuner.
One easiest thing is to contact the computer manufacturer and ask them about the driver for your TV tuner for Windows 7.
Sep 21, 2011 | Computers & Internet
I tune my bass guitars on the tuner no problem, i have recently tried to tune an electric guitar, but the tuner locks up... any suggestions please.... Thanks ... J
Make sure you have adequate input level to the tuner... some guitars MAY have inadequate output to be recognized CONTINUALLY by the tuner.
Jul 05, 2011 | Korg GB-1 Pitchjack Plug-In Guitar and...
TV wont recognize lower channels
Your Tuner might be faulty but before replacing it there's also 1 thing to be checked.
You need to bring your unit to repair to checked the band switch I.C. before replacing the tuner.
Tuner is divided into 3 bands (VL,VH,UHF) since you have no reception on the lower channels, it seems that your VL bands is faulty that might be cause by defective tuner or Band switch I.C. located near your tuner.
Jan 03, 2011 | RCA Televison & Video
Intex tv tuner driver for windows xp 64-bit
driver for Intex tv tuner saa 7130 hl Windows 7
Sep 21, 2009 | Tvone TV-205A Television
Play & Record VHS through TV Tuner Card
You need to connect the ariel to the vcr, then the vcr to the card, using a male/female fly lead. Then I suggest putting an origional film tape into the vcr, press play on the vcr and then scan in the channels on the card. It should pick up the vcr's output of the film that is playing.
Jun 05, 2009 | HP Expresscard TV Tuner For Windows Vista...
Laptop doesn't recognize tv tuner anymore pt. 2
first off lets try pluggin in something else into that port to see if it will recognize that. if it does then we know it is not the laptop that is in question but the software or device mangaer properites.
Oct 01, 2008 | HP Expresscard TV Tuner For Windows Vista...
Hi!
You may check Device Manager first to check if your TV tuner is still properly installed or still detected by your computer. For Windows XP - Control Panel > System > Hardware > Device Manager and check if the TV tuner is still there.
If you cannot see the TV tuner under Device Manager , unplug then replug your tuner and see if something will pop up under "Other Devices" (still under Device Manager). If it does, then you need to right click it and reinstall the driver. You can just download the driver/software over the net.
Now, if your computer does not detect it at all try another PC to test if the problem is with your PC or just the tuner.
Good luck and have a nice day!
Sep 30, 2008 | HP Expresscard TV Tuner For Windows Vista...
Alpine CDA-9855 won't recognize SIR-ALP1
I also had this problem. I had to go through the menu into the setup and then into tuner settings. There should be an option called tuner area. If you set it to area 1 it should start working. For some reason the sirius only works on area one. Hope that solces your problem
Jun 19, 2007 | Sirius Satellite Radio Sirius SIR-ALP1...
bitcount Cleartune - Chromatic Tuner Logo
94 people viewed this question
Top bitcount Apps Experts
Erin Wood
Erin Wood
Are you a bitcount App Expert? Answer questions, earn points and help others
