Question about Vivitar Cameras
How to charge your vivicam 7122 - Vivitar Cameras
How do I read my micro sd card?
A usb micro sd card reader to a usb port. They are cheap at most box stores and most modern operating systems worth a pot of beans should have the drivers to read it.
Oct 01, 2014 | Vivitar ViviCam 7122 Digital Camera Blue...
How do I delete all images on my vivicam 7122?
Turn the camera on. It will be in the mode for taking pictures.
Press the MODE button twice. The camera is now in the mode for viewing pictures from the memory.
Press the button with the TRASH CAN symbol. It stands for Delete
You now have three (3) options:
  • Delete this photo
  • Delete all photos
  • Cancel
You will probably have to use the Up/Down/Left/Right keys to highlight the option you want before pressing the SET button in the centre of the navigation ring to select it.
There's an online version of your camera's user manual here. Have a read. You might learn some tricks.
Vivitar ViviCam 7122 User Manual
Sep 16, 2014 | Vivitar ViviCam 7122 Digital Camera Pink...
Need driver for 7122
Do you really need a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Jan 26, 2014 | Vivitar ViviCam 3785 Digital Camera
How I can charge my batteries on my Vivitar Vivicam 8025 if I don't have a battery charger?
Yes, you may charge the battery through the USB connection. Bear in mind that not all computer USB ports put out enough current to charge batteries. You may also use an AC-powered USB charger, such as used for some cell phones.
Dec 13, 2012 | Vivitar ViviCam 8025 Digital Camera
How do i get rid of the time stamp?
Go into you settings.(click the "set" button) Then you can change a host of options as you scroll right (hitting the trashcan icon) - including removing the time / date stamp.
Aug 28, 2012 | Vivitar ViviCam 7122 Digital Camera Pink...
Vivicam 8025 what does the MSDC screen mean while charging
The MSDC indicates that the camera has recognized it's connected to a computer.
The red light indicates that the camera's battery is charging.
Aug 03, 2012 | Vivitar ViviCam 8025 Digital Camera
Cannot open case to install batteries. Pushing door in direction of arrow. Is there something else?
I was able to get it open by putting my finger on the battery door back toward the screw and pushing it down and forward until it popped open. I worked for hours trying to get it open. I found a video on uTube that gave an opening review of the camera and I saw how he opened it. Hope this helps.
May 25, 2012 | Vivitar ViviCam 7122 Digital Camera Blue...
I cant get disc to download software needed to download pictures
You don't need any special software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
May 22, 2012 | Vivitar ViviCam 7122 Digital Camera Pink...
How long do you need to charge the battery of a Vivicam x029 for the first time
Normally it will take 3 hours to fully charge the battery on a Vivicam 3915 Digital camera.
Mar 07, 2011 | Vivitar ViviCam 3915 Digital Camera
Cameras Logo
112 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
