Question about Whirlpool Washing Machines
Whirlpool stylemaster washing machine lint filter
Does it have a lint filter and if so where is it? I am sick of my dark clothes coming out with fluff all over them..
  • 37 Answers
SOURCE: washing machine lint
fluffed up,
If you have a manual filter..make sure it's clean. If you do, and it is, the tub drain could be blocked.( it is under the agitator and basket, requires disassembly) If you don't have a manual filter, the self-cleaning filter/ trap could be clogged.(it is underneath, also requires some disassembly. If you have tools and feel comfortable with things mechanical, get a repair manual from the library, maybe you can tackle the fix.
hope this helps,
handiman518
Posted on Jan 17, 2008
MY REPAIRMAN
  • 61 Answers
SOURCE: I have an older Whirlpool
WHIRLPOO STOP USING FILTER IT MAY BE COMING FROM THE TUB. TRY RUNFIN A WASER CLEANER LIKE C.L.R. CAUSIM LIME AND RUST REMOVER. AND TAKE THE SOFTER OUT BY PULING THE BLUE RIND UP AND PULL THE SOFERNER UP AND PUT IN WASHER TO GET CLEAN IN HOT WAER LOW CYCLE.
Posted on Jan 25, 2009
  • 490 Answers
SOURCE: fluff on left on clothes
the lint filter is your problem needs to be cleaned out, the agitator which is the thing in th middle of the machine houses the lint filter the top should just pull off
Posted on Jun 07, 2009
SOURCE: lint showing up on dark clothes
lint
Posted on Oct 26, 2009
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Washer leaves lint & white smears on the cleaned cloth
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Why won't my Whirlpool Washer Stylemaster #907675 fully drain?
The pump may be failing. That's where the leak is coming from.
Jul 28, 2014 | Whirlpool Washing Machines
Whirlpool stylemaster 4217141 rev
Try cleaning the lint filter on the bottom of the inner opening. Lift up and clean filter.
Oct 15, 2013 | Washing Machines
Lint on dark clothes in my Whirlpool Cabrio washing maching
sorry there right ..your not using he or low suddsing detergent ,or your using to much..as the water pumps out of unit the sudds stick to side of tub than when rinse water comes in it washes back on your clothes...i can only give you tips and something to look for...look for water not drainning fast enough ,,cut down on detergent,,wash your dark clothes first..give your unit a bleach clean about a pint of bleach..keep me posted onthejob
Feb 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I have an older Whirlpool washing machine (Stylemaster # 907675.) It leaves behind lint galore and white smudges that are almost impossible to clean off. Do you think it has a filter that might need...
Jan 25, 2009 | Washing Machines
Lint trap
There should be a rectangular flap on the top panel at the rear right of your dryer. the lint filter is in a chute if there is just a hole here then the filter is missing.
Mar 15, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
75 people viewed this question
Dan Webster
Dan Webster
Sal De
