Question about Reliance Water Heaters
Hot water heater keeps kicking out - Reliance Water Heaters
  • Reliance Master
  • 5,245 Answers
  • 2692 Answers
SOURCE: Water heater won't run long enough for hot water.
Common problem if the thermo couple goes bad.Replace thermocouple with a universial on.A common hardware item.
Posted on Dec 14, 2008
SOURCE: My hot water heater keeps kicking off and the
Use following link for Rheem tankless troubleshoot:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
I believe error code C7 is same as error code 76
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 23, 2011
  • 5245 Answers
SOURCE: rheem hot water heater not kicking flame to high heat
1) Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Bad gas control valve, low gas pressure, dirty combustion parts, inadequate venting, clogged flame arrestor screen located under burner
Posted on Mar 06, 2013
  • 5245 Answers
SOURCE: hot water heater kicks breaker
Single-phase residential Electric tank-type heater?
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
Posted on Apr 08, 2013
  • 5245 Answers
SOURCE: kick out breaker
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html
Call GE and they will send replacement panel
Gene
h
Posted on Jan 23, 2014
Why is there no hot water?
Check the heating elements for continuity.
Feb 13, 2016 | Water Water Heaters
My caravan carver heaters pressure relief vale keeps blowing any ideas please
Not familiar with that exact heater but if it is an electric heater with a top and bottom element this may be the problem. Electric water heaters usually heat water off the bottom element. If a lot of hot water is used then the top one kicks in through the temperature controls. In some cases if the bottom element burns out, it will try to heat everything with the top element. This sometimes causes the water in the top of the tank to actually get too hot and it opens the relief valve. So you may have a bottom element bad. Otherwise your relief vale may need replaced or you have a sticking temp control making it get too hot.
Apr 11, 2015 | Water Heaters
My hot water heater keeps kicking off and the theramsatic is flashing C7 76. How do I reset it?
Jan 31, 2011 | Rheem Tankless Hot Water Heater...
Lose of hot water at times
If you keep kicking the reset you have a thermostat that is bad...it could be either the top or the bottom one...but you will have the check and see if it is switching to the bottom element or not...if it does switch to the bottom it is the bottom t-stat bad, if not then the top one is bad...
heatman101
Apr 28, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water Heater Keeps Going Off
is there a check valvle on hot water side of heater,a flow restriction of some sort, water pressure to the heater, a filter in the line, line pressure in the heater kicks out burner, when you turn on the water, line pressure drops, heater comes on, when you turn on water in other part of house, heater should not fire, so there has to be a check valve somewhere,in heater?
Jan 24, 2010 | Noritz 6.9 Gallon Residential Tankless...
Code 11 01 - Hot Water Heater Kicks Off
if you have build up in the heat exchanger it will cause the unit to use more gas to heat your water, if the gas line isn't sized properly then your going to kick the error codes off. it sounds like you have two problems, first you have build up in your heat exchanger and it needs to be flushed and second you need to get a bigger gas line to it
Aug 19, 2009 | Water Heaters
Dec 14, 2008 | Water Heaters
Water Heaters Logo
55 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
