Question about HP Office Equipment & Supplies
Hp photosmart 6520 paper mismatch error - HP Office Equipment & Supplies
SOURCE: Word Settings for Printing Postcards
I found the fix!! Once you have your size settings typed into your page layout screen and applied to the document, click print. Once you select your printer, click on properties (or printer preferences) click on the features tab (the tab next to printing shortcuts) and go to the resizing options section. click on paper size bar and scroll down to custom. once in the screen, give the shortcut a name you'll recognize, type in your dimensions in the provided spaces click save. once you go back to the features screen, scroll back down to custom and select your shortcut that you just created and apply it to both the paper type and paper size. click ok and go back and click ok to print! Hope this makes sense..if not, go to HP's website and type in your product name, type paper mismatch in the keyword search bar and click ont the first link in the found section. It will give you the same step by step instructions....
Posted on Jun 21, 2008
  • 6 Answers
SOURCE: Can't Print Invitations
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Posted on Jun 27, 2009
sgoswami
  • 114 Answers
SOURCE: HP Photosmart Premium c309a series will not print
Try This :
Try printing from micrsoft word; Click on tools;
Click on Envelopes and Labels
Click on "OPTION"
Under the TAB Envelope Option you will get Evelope Size;
Scroll Down to the bottom you will get an option "Custom Size " Select it;
Set the accurate size of the envelope;
Click on Printing Options
Select the Feed method and make sure you do it the same way;
And then try to print this should resolve your Issue
otherwise let me know
Regards Soumajit
Posted on Sep 21, 2009
Testimonial: "Still not working. Great idea, tho."
  • 19 Answers
SOURCE: Photosmart C309a series Printer (brand new) will not print
check the Tray. there are markings on the tray that tell the printer what paper is loaded, if the tray isn't in the percise location of type of paper, you'll get that error message. If that isn't it, then check the sides of the tray and see if there is any damage. sometimes the tabs on the trays that tell the printer what paper is in it, get broken. If that isn't it, then look inside the printer where the Tray goes in, and look for damage, or bent metal feelers that rub against the tray,
Posted on Oct 01, 2009
SOURCE: Print Envelopes with hp c309a "Paper Mismatch" error
Even though the icon on the printer shows the envelopes entering the printer narrow side first, you have to set the printer up for, and feed the envelopes through, wide side first.
Posted on Dec 19, 2009
HP 6520 keep getting lower photo tray error have to hold tray in to get it to print also getting ink error that a cartridge is damaged or paper jam? Wth it needs to decide what it wants! I've
That's a great printer but HP support can make your hair fall out.
Sounds like a misaligned sensor. Look for a micro switch probabably on the tom inside left. Tape that shut with duct tape and maybe a bit of cardboard. You can try to reposition it too, but there is little adjustment tolerance. If that doesn't take, it may require replacement. Working pulls for the hp's are inexpensive on eBay. You can also try to junction the leads together temporarily.
Nov 25, 2014 | HP Photosmart 6520 e-All-in-One -...
I am using quickbooks 2005 and am trying to print full page checks. I am getting a 'paper mismatch' error and cannot print my checks.
Welcome to FixYa.
Paper mismatch errors occur because the product scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the product, the product reports a 'Paper Mismatch' error.
How do you load your check in the printer?
Keep me posted.
Jas247
Jun 15, 2011 | HP Photosmart 8250 InkJet Printer
I am trying to print invitations size 5.5 by 8.5 on my HP Puotosmart C5580 printer and I am having a problem. It keeps telling me that I have the incorrect paper. Would you please advise? Thanks
Go to HP Solution Center
Click Printer Settings
Click Printer Preferrences
Go to Paper Size
Look for the size of your media or
choosee Custom
Then type the width and length of the paper
then save it
change paper type to plain paper
then got to Printers under control panel of your PC
right cick on the printer icon then choose printer properties
click printer preferences
got to features tab
Go to Paper Size
choosee Custom
then save it
then try printing again
you can also refer to the link below for additional info
'Paper Mismatch,' or 'Paper Size Mismatch' Error Message Displays When Printing in Microsoft Word
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01824353&cc=us&lc=en&dlc=en&product=3575276&tmp_track_link=ot_search
'Paper size mismatch' Message Displays on the HP Photosmart Printer
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01631553&cc=us&lc=en&dlc=en&product=3575276&tmp_track_link=ot_search
Hope I help you a bit.
You can also send me questions on my
personal email - christian4122@yahoo
Your's Truly,
Christian from HP
Mar 27, 2011 | HP Photosmart C5580 All-In-One InkJet...
Paper micmatch error
use the HP ImageZone ...
go to printer settings
then go to the paper/quality tab..
in the first box...."print task quick sets"
choose the option named "default print settings"
select ok and close the Image Zone.
Dec 19, 2009 | HP Photosmart C5580 All-In-One InkJet...
Dec 19, 2009 | HP Photosmart Premium C309A All-In-One...
How can I print envelopes on my HP C5180. I've had it over 2 years and have never been able to get it to print any size envelopes. I always get a 'paper mismatch' message. HP tech support has never...
I tried all of the suggestions on here and nothing worked. My envelopes are 5x7.3. So, I finally just put in 5x7 and lo and behold, even though there truly was a paper mismatch this time since that was NOT the size of the envelopes, they printed. I did have to move the text boxes some to make them print correctly. So, I guess the solution for my printer is to actually mismatch the size of the paper/envelope so that you will NOT get the "paper mismatch" error message. Will it work on other size envelopes? I have no clue. This is the first time I've ever been able to print an envelope at all with this printer that I've had 2 or 3 years.
Dec 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
Printing to 4 x 6 paper
Hello oyam26,
For any paper mismatch issue, first thing you do is try to set the paper type to plain. This will fix the issue in most of the cases.
gud luck
Nov 01, 2008 | HP Photosmart C4280 Aio Printer
Paper mismatch when recieving a fax
I understand that while receving faxes, you are experiencing with paper mismatch error message.
Please select the paper type as plain paper fromt the front panel of the All-in-One and try to recevie faxes.
Mar 27, 2008 | HP Photosmart 2710 All-In-One InkJet...
118 people viewed this question
Seeker5211
Seeker5211
