Canon ir3170 code E0021-0001 - Office Equipment & Supplies
2 Suggested Answers
canontech
  • 1219 Answers
SOURCE: KINDLY CLARIFICATION FOR IR3170 CANON
this is error code for ITB HP sensor detection error. As possible solution you can try to clean the ITB HP sensor and belt rollers.
Call service, the copier needs to be dismantled badley... :-)
Hope that helps!
Posted on Sep 13, 2011
Why is system software of canon ir 3170ci not loading?
LOAD SOFTWARE WITH PRINTER DISCONNECTED FROM COMPUTER THEN CONNECT PRINTER
Aug 17, 2014 | Office Equipment & Supplies
How to connect printer to computer without installation disc
Download mode error comes in Canon Ir3170 only when the shutdown was improper. Kindly off the switch on the right side panel and plug out from complete power supply. then reboot the machine. It will work perfectly.
Dec 02, 2013 | Samsung CLP620ND Printer
How to clear e004 for ir3170
The SSR has a short circuit.The DC controller PCB is faulty.The SSR used to drive the fixing heater is found to have a short circuit.The error must be reset in service mode COPIER - FUNCTION - CLEAR - ERR.
Feb 21, 2013 | Canon imageRUNNER C3170I Color Copier
Need user and password of canon ir3170
here's the original disk http://www.precisionroller.com/manuals-for-canon-imagerunner-c3170u/products.html. Try these Default system password: user:7654321 , psw:7654321 Default technician password. 11111111 Control panel password: user: Administrator , psw: password
Oct 30, 2012 | Canon ImageRUNNER 3570 Copier/Printer
KINDLY CLARIFICATION FOR IR3170 CANON ERROR CODE -E000070-0002
Hope that helps!
Sep 13, 2011 | Canon imageRUNNER C3200 Copier
ERROR E000020-0081 in the screem IR3170 C
these is developer/drum related error.
One of possibilities can be that you need to clean the drum patch sensor that reads the drum surface or replace drum unit.
The drum patch sensor is located above the drum unit inside of copier. For better understanding you will need service manual. emma.servis@gmail.com
Hope that helps!
Jun 08, 2011 | Canon imageRUNNER C3170U Color Copier
How much the price of drum ir3170 TQ
hello
part number 4229A003AA, go to this link
www.iteminc.com they have five in stock
also, http://www.worldclassink.com/Canon-4229A003AA-Drum-item5406.html
please rate my service with 4 thumbs up
Dec 02, 2010 | Canon imageRUNNER 5020 Copier
My canon photocopier ir3170 is indicating e255-001,what fault do we have
you probably got the E225-001 error because the error that you say is not in the manual.
E225 CIS light intensity error.
At time of power-on or at the start of a job, the machine cannot find out whether the lamp has gone on normally for shading correction.
You must call a tech to verify the scanning lamp (xenon tube), CIS, inverter PCB, and reader controller PCB.
Nov 19, 2010 | Office Equipment & Supplies
Ir3170 error code e000732-0001
This error code is a communication error between the Reader Unit and the Copier (Printer Unit). Shut down and un-plug the Copier. Unplug and reset all the connectors on the rear and sides of the copier. One interface cable is responsible for communication between the reader unit and printer unit. This may solve the problem. Possible the cable is defective see if cable or cable socket is damaged.
This error also can be caused by a defective reader controller/DC Controller or Main Controller PCB.
If the simple cable check does not solve the problem a service call by a Canon dealer will required.
Mar 16, 2010 | Canon Office Equipment & Supplies
Have ir3170 with error code E000020-008
the sensor inside the copier is dirty. you have to remove the drum and clean the sensor assmbly
Oct 13, 2009 | Canon Office Equipment & Supplies
29 people viewed this question
k24674
