Question about Mitsubishi WD-65738 DLP TV
Status light blinks green
I turn on the television, the green status light will not stop blinking and the TV never comes on. I tried powering completely off and unplugging, but problem persists.
  • 1694 Answers
SOURCE: Mitsubishi WS65513 with blinking green light
Download Chris@ChrisAndNat.com .........T.
Posted on Nov 09, 2007
  • 1694 Answers
SOURCE: TV won't turn on
Ready? The solution is = Replace four capacitors inside DM module 1000mf / 25v high temp. For details.........Look @..
www.Chris@ChrisAndNat.com.................T.
Posted on Nov 23, 2007
SOURCE: blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Posted on Sep 19, 2008
SOURCE: green power light will not stop flashing and tv will not turn on or off
I'm having the same problem.  Did this suggestion work?
Posted on Nov 16, 2008
SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Posted on Jul 16, 2009
Steady blinking green light on Mitsubishi LCD model LT 55164
I also have a Mitsubishi LT 55164 with blinking green status light...does nothing else...reset does no good, also tried to reload software with no difference. Replaced power and inverter boards button stop the same. No obvious bad components on boards. Help! Anyone ever actually fix one of these?
Aug 29, 2015 | Mitsubishi LT55164 55 in LCD TV
I have tried to turn my television on and the status light blinks for about a minute, you can hear the TV try to start up and then the whole system shuts down without anything actually powering up. Also...
Unplug the tv for about a minute - plug it in and press the reset button on the front of the tv - hold it until the light blinks. The set should come on in a minute of two - if not try the same routine again.
Jan 16, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Hi, i have here a mitsubishi WD-57733. once the unit is switch ON, green LED light and a few seconds the status LED light then shuts off. I think light engines good since i just replaced a new lamp.
hello i've just checked the manual for here is some information
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Error 37
HELLO. the fist this is turn on the set and just let it do it's own thing.!!! for around 7mins to 15 min's and see what happen's and then tell me ok. let me know ok
Aug 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV won't come on
Menu and Input/Device button on front panel for 5 seconds, then this will flash a 2 digit seq. this will be your error code.
Apr 05, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Green LIght Blinking
Does the led ever stop blinking? No ..well in that case generally this indicates a standby voltage problem...if all those voltages ok then the cuircit known as digital module is at fault. also make sure the lockout has not been activiated. i really dont think it could but to unlock hold menu button down for 10 seconds. After all that i believe it would be a bad digital module
Willie@fordtv.com
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Mitsubishi WD-65738 DLP TV Logo
42 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
