Question about Hobart Dishwashers
Float level sensor
Ft900
Where is the level sensor located in my kenmore ultra wash portable dishwasher?
Inside the cabinet of the dishwash in the area of the water is a float that is the level sensor float.
Nov 19, 2016 | Kenmore Dishwashers
I have a auto chlor model a4 dishwasher and when I push the fill button it only fills for 3 seconds and stops and if I fill it up by holding the button down and run it threw it's cycle when it goes into...
Hi John,
This sounds like a misadjusted water level sensor. This is a commercial dishwasher but the principles are the same. I would check the water level sensor to make sure that there is no debris under it or a leveling sensor bent causing the machine to think it is at the proper water level to begin washing when it is not. This may be a mechanical lever float type switch or an actual electronic sensor that will detect where the water level is. Most household DW's will have the mechanical float switch that will float with the water level and shut off the fill solenoid when the proper level is reached. You are having to defeat this process by holding the button in to override either a faulty sensor (replace it) or a misadjusted float switch. These would be the too most likely causes of this problem. I hope this helps!
Jun 04, 2014 | Dishwashers
Husqvarna ft900 won't start
did you open the choke all the way? also, what was the temperature when you attempted this at the onset? if it is cold outside, then set the tiller in the sun for at least a half hour then try starting.
May 30, 2012 | Husqvarna 12" Tiller Briggs 900 Series...
2005 sorento LX 3.5 code po463
Possible causes - Fuel level sensor circuit harness is open or shorted
- Fuel level sensor circuit poor electrical connection
- Faulty fuel level sensor in fuel tank (most common cause) P0463 Description The fuel level sensor is mounted in the fuel level sensor unit. The sensor detects a fuel level in the fuel tank and transmits a signal to the Engine Control Module (ECM). The fuel level sensor consists of two parts, one is mechanical float and the other side is variable resistor. The fuel level sensor output voltage changes depending on the movement of the fuel mechanical float
Feb 21, 2012 | 2005 Chevrolet Malibu
Just bought the ft900 today but did not receive a manual was told to drain existing oil and replace with new BUT ,,, how much oil do i REfill it with ?
always call your site of purchase for missing manuals, after you purchase. use the manual to determine the amount - Do Not Guess!!
Aug 26, 2011 | Husqvarna 12" Tiller Briggs 900 Series...
How do i fix or replace the break light inside my dash. It stays on even when there is nothing wrong with my breaks
The brake light is a warning that your fluid level is low. Check the brake fluid reservoir if the fluid is in minimum level. If the level is okay and it is full, the problem would be float sensor in the reservoir.
Please check the connector of the float sensor if it is connected and try to clean the metal pins( might be full of dirt and grease ).
The float might be stuck to "low" thats why the brake light up( move the float up and down to free it ).
Hope that helps you out.
Thank you for using FixYa!
Jun 30, 2011 | 2002 Mitsubishi Diamante
P0464
P0464 - Fuel Level Sensor Circuit Intermittent
An intermittent low voltage is sent from the sensor is sent to ECM.
The fuel level sensor is mounted in the fuel level sensor unit. The sensor detects a fuel level in the fuel tank and transmits a signal to the ECM or PCM.
It consists of two parts, one is mechanical float and the other side is variable resistor. Fuel level sensor output voltage changes depending on the movement of the fuel mechanical float.
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
Possible causes
- Fuel level sersor circuit harness or connectors is open or shorted
- Fuel level sensor may be faulty
Possible solution
Replaced fuel level sensor.
Check it and keep us news.
May 17, 2011 | Hyundai Santa Fe Cars & Trucks
P0463 Fuel Level Sensor Circuit High Input Any ideas on the problem and possible solutions?
P0463 - Fuel Level Sensor Circuit High Input
An excessively high voltage is sent from the sensor is sent to ECM.
Symptoms
Possible causes
Possible solution
Hope helps (remember to rate this answer).
May 07, 2011 | Ford Explorer Cars & Trucks
Is there an easy cleaning guide for the ft900
check in Google by your query!
Mar 29, 2010 | Dishwashers
Coolant sensor location
it should be located on the bottom of the rad
Dec 10, 2008 | 1998 Chevrolet Cavalier
Dishwashers Logo
14 people viewed this question
Top Hobart Dishwashers Experts
Jason
handygirl911
handygirl911
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
