Question about Dell Inspiron 15r n5110 Laptop
Boot problem \boot\bcd 0xc000000e - Dell Inspiron 15r n5110 Laptop
2 Suggested Answers
rwoods142
  • 119 Answers
SOURCE: after format completes cp gets restart and occur file:\boot\bcd status:0xc000000e
All credit to J W Stuart
"How to repair and reboot to Windows 7:
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install Now option) instead choose the 'Repair your computer' option located in the lower left of the display.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options. Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
Note: Please perform step j as detailed, startup repair must be run multiple times.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window. Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'. This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer."
Posted on Nov 23, 2012
HP Color Laserjet 5550dn printer connected in network configured through server, showing error 0xc0000005 while clicking on printer properties in any client system?
You have hacked or infected files on your computer.
Check your BCD and do the below fix if necessary (at your own risk)
In Windows open CMD as Administrator and type BCDEdit and enter, if your Windows Boot Loader Path is xOsload.exe then you need to remove some files and repair your BCD.
NOTE: you will need to re-activate Windows afterwards, so make sure you have your Windows 7 key handy.
Boot to Windows Repair - Command
Del D:\Windows\System32\xOsload.exe
Del D:\Windows\System32\xNtKrnl.exe
Del D:\Windows\System32\Drivers\oem-drv64.sys
attrib c:\boot\bcd -h -r -s
ren c:\boot\bcd bcd.old
bootrec /rebuildbcd
Oct 14, 2016 | HP Office Equipment & Supplies
Windows 8 error code 0xc000000e
Hi I have this error code 0xc000000e windows 8, You get three options,
1. Enter to retry
2. Press F8 for start up settings
3. press F9 for to use a different operation system.
First two options do nothing, F9 will restart computer, and the I can boot from the boot disk. I have tried to rebuild the startup files, from the disk nothing is working. I can't get into the Safe mode. Guess only option is save all files to a back up HDD, I even tried to restore to a past date.
Nov 17, 2012 | Computers & Internet
Missing boot manager
To run the Bootrec.exe tool, you must start Windows RE.
To do this, follow these steps:
Put the Windows Vista or Windows 7 installation disc in the disc drive, and then start the computer.
Press a key when you are prompted.
Select a language, a time, a currency, a keyboard or an input method, and then click Next.
Click Repair your computer.
Click the operating system that you want to repair, and then click Next.
In the System Recovery Options dialog box, click Command Prompt.
Type Bootrec.exe, and then press ENTER.
Note To start the computer from the Windows Vista or Windows 7 DVD, the computer must be configured to start from the DVD drive.
For more information about how to configure the computer to start from the DVD drive, see the documentation that is included with the computer or contact the computer manufacturer.
Bootrec.exe options
The Bootrec.exe tool supports the following options. Use the option that is appropriate for your situation.
Note Use the Bootrec.exe tool to troubleshoot "Bootmgr Is Missing" issue.
If rebuilding the BCD does not resolve the startup issue, you can export and delete the BCD, and then run this option again.
By doing this, you make sure that the BCD is completely rebuilt.
To do this, type the following commands at the Windows RE command prompt:
bcdedit /export C:\BCD_Backup
c:
cd boot
attrib bcd -s -h -r
bootrec /RebuildBcd
/FixMbr
The /FixMbr option writes a Windows 7 or Windows Vista-compatible MBR to the system partition. This option does not overwrite the existing partition table.
Use this option when you must resolve MBR corruption issues, or when you have to remove non-standard code from the MBR.
/FixBoot
The /FixBoot option writes a new boot sector to the system partition by using a boot sector that is compatible with Windows Vista or Windows 7.
Use this option if one of the following conditions is true.
The boot sector has been replaced with a non-standard Windows Vista or Windows 7 boot sector.
The boot sector is damaged.
An earlier Windows operating system has been installed after Windows Vista or Windows 7 was installed. In this scenario, the computer starts by using Windows NT Loader (NTLDR) instead of Windows Boot Manager (Bootmgr.exe).
/ScanOs
The /ScanOs option scans all disks for installations that are compatible with Windows Vista or Windows 7.
Additionally, this option displays the entries that are currently not in the BCD store.
Use this option when there are Windows Vista or Windows 7 installations that the Boot Manager menu does not list.
/RebuildBcd
The /RebuildBcd option scans all disks for installations that are compatible with Windows Vista or Windows 7.
Additionally, this option lets you select the installations that you want to add to the BCD store.
Use this option when you must completely rebuild the BCD.
hope this helps
Oct 14, 2012 | eMachines El1852g-52w Pentium E5800...
0xc000000e
1. First Load Windows Recovery environment from Windows 7 or Server 2008 R2
2. Open Diskpart and make problematic partition Active
3. Open bcdedit and you should get something like this:
Windows Boot Loader
identifier {default}
device unknown <===0xc000000e problem!
path \Windows\system32\winload.exe
description Windows Server 2008 R2
locale en-US
inherit {bootloadersettings}
recoverysequence {e0025536-b36d-11de-aadd-ddc0b5870e2c}
recoveryenabled Yes
osdevice unknown <===0xc000000e problem!
systemroot \Windows
resumeobject {e0025534-b36d-11de-aadd-ddc0b5870e2c}
nx OptOut
hypervisorlaunchtype Auto
4. Enter these commands:
bcdedit /set {Your-OS-Identifier} device partition=X:
bcdedit /set {Your-OS-Identifier} osdevice partition=X:
bcdedit
Where X: - drive letter with your problematic OS in Windows RE. You can find it by opening notepad and pressing save
5. Reboot
if you don't have a copy of the dvd you can try and boot to a recovery partition by tapping f8 @ boot and you should be able to go to 'repair my computer' and hit enter. you can also download the recovery console from the internet and burn it to a cd and run it. good luck
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Feb 11, 2012 | Toshiba Computers & Internet
BOOTMGR IS COMPRESSED
Validate and Fix the File System
This runs the check disk program to detect and attempt to repair problems on one partition. For example, to repair the C: drive:
At the prompt type chkdsk c: /r
Repair the Boot Process
Typically this is used if Windows doesn't start and you can't get to the safe mode menu. You might also replace the Master Boot Record (MBR) and boot sector if you suspect a virus infection. There are four options:
New MBR - Insert a new generic MBR without changing the partition table.
At the prompt, type: bootrec /FixMbr
New Boot Sector - Insert a new Windows 7/Vista compatible boot sector. It will automatically insert the right type of sector for the file system type (NTFS, FAT32, etc.)
At the prompt, type: bootrec /FixBoot Rebuild BCD - Rebuild the Boot Configuration Data (BCD). The BCD controls which partition boots. This option will let you select which installations to include in the BCD.
At the prompt, type: bootrec /RebuildBcd Find OSes - Scan the system for all OS installations that are compatible with Vista/2008 and will also show those that are currently included in the BCD.
At the prompt, type: bootrec /ScanOs
in the end type in C:/expand bootmgr temp
Aug 24, 2011 | Computers & Internet
Samsung R519 wont boot up get a status code 0xc000000e
http://www.wiki-errors.com/wiki-errors.php?wiki=0xc000000e
Apr 29, 2011 | Samsung Computers & Internet
I just installed Windows 7 I turn off the computer, and when I turn it back on later it said bootmgr is compressed press Ctrl Alt Del
try this,it works for me
play with it a bit,see how u go
Aug 14, 2010 | Computers & Internet
What is file error 0xc000000e
File: \Boot\BCD
Status: 0xc000000e
Info: An error occurred while attempting to read the boot configuration data.
Windows failed to start. A recent hardware or software change might be the
cause. To fix the problem:
1. Insert your Windows Installation disc and restart your computer.
2. Choose your language settings and then click "Next"
3. Click "Repair your computer"
If you do not have this disc, contact your system administrator or computer
manufacturer for assistance.
ERNZ
Feb 03, 2010 | Toshiba Sattelite A105-S2051 Notebook
BOOT MGR MISSING
Rebuild the BCD store by using the Bootrec.exe tool If the previous method does not resolve the problem, you can rebuild the BCD store by using the Bootrec.exe tool in the Windows Recovery Environment. To do this, follow these steps: 1. Put the Windows Vista installation disc in the disc drive, and then start the computer. 2. Press a key when you are prompted. 3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next. 4. Click Repair your computer. 5. Click the operating system that you want to repair, and then click Next. 6. In the System Recovery Options dialog box, click Command Prompt. 7. Type Bootrec /RebuildBcd , and then press ENTER. • If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type Yes . A confirmation message appears that indicates the entry was added successfully. • If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command. Bcdedit /export C:\BCD_Backup ren c:\boot\bcd bcd.old Bootrec /rebuildbcd 8. Restart the computer.
Sep 08, 2009 | Dell Inspiron 1525 Laptop
Ntoskrnl 0xc0000098 error
To Solve the problem refer to steps below
To run the Bootrec.exe tool, you must start Windows RE. To do this, follow these steps:
  3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
  7. Type Bootrec.exe, and then press ENTER.
Note To start the computer from the Windows Vista DVD, the computer must be configured to start from the DVD drive. For more information about how to configure the computer to start from the DVD drive, see the documentation that is included with the computer or contact the computer manufacturer. uparrow.gifBack to the top Bootrec.exe options loadTOCNode(2, 'moreinformation'); The Bootrec.exe tool supports the following options. Use the option that is appropriate for your situation.
Note If rebuilding the BCD does not resolve the startup issue, you can export and delete the BCD, and then run this option again. By doing this, you make sure that the BCD is completely rebuilt. To do this, type the following commands at the Windows RE command prompt:
  • bcdedit /export C:\BCD_Backup
  • c:
  • cd boot
  • attrib bcd -s -h -r
  • ren c:\boot\bcd bcd.old
  • bootrec /RebuildBcd
/FixMbr loadTOCNode(3, 'moreinformation'); The /FixMbr option writes a Windows Vista-compatible MBR to the system partition. This option does not overwrite the existing partition table. Use this option when you must resolve MBR corruption issues, or when you have to remove non-standard code from the MBR. /FixBoot loadTOCNode(3, 'moreinformation'); The /FixBoot option writes a new boot sector to the system partition by using a boot sector that is compatible with Windows Vista. Use this option if one of the following conditions is true:
  • The boot sector has been replaced with a non-standard Windows Vista boot sector.
  • The boot sector is damaged.
  • An earlier Windows operating system has been installed after Windows Vista was installed. In this scenario, the computer starts by using Windows NT Loader (NTLDR) instead of Windows Boot Manager (Bootmgr.exe).
/ScanOs loadTOCNode(3, 'moreinformation'); The /ScanOs option scans all disks for installations that are compatible with Windows Vista. Additionally, this option displays the entries that are currently not in the BCD store. Use this option when there are Windows Vista installations that the Boot Manager menu does not list. /RebuildBcd loadTOCNode(3, 'moreinformation'); The /RebuildBcd option scans all disks for installations that are compatible with Windows Vista. Additionally, this option lets you select the installations that you want to add to the BCD store. Use this option when you must completely rebuild the BCD.
http://support.microsoft.com/kb/934540/en-us
Mar 22, 2009 | Sony VAIO VGN-NR180EW Notebook
Dell Inspiron 15r n5110 Laptop Logo
Alun Cox
