Question about Singer SEARS KENMORE 158 Sewing Machine Feed Dog
I need to oil my sewing machine
Where does the oil go and how much do I use
Do I need to oil machine?
Yes all sewing machines need to be oiled, but only use oil specifically formulated for sewing machines. Any sewing machine repair and sales business can supply the right oil.
Jul 10, 2017 | Sewing Machines
I have an old 281-3 machine that was given to me. It appears to work but I need to get oil for it. what kind do I buy? Thanks
sewing machine oil. go to your local sewing machine sales and get one that has a spout that can be extended.
Jul 07, 2017 | Sewing Machines
Do i need to oil my necchi sewing machine? if so how? i have a model 4825.
The following web site indicates the machine should be "lubricated as needed." So, you should probably consult the owner's manual. Your machine is computerized which means there is usually limited oiling required, perhaps the hook.
Necchi 4825 Review Sewing Insight
Be sure to use good quality sewing machine oil recommended for your machine (NOT 3-in-1, WD-40, cooking oil, etc.)
Instruction Manual Necchi 4825
Jul 25, 2016 | Necchi Sewing Machines
What about Oiling?
If you look at the Oiling Instructions in the owner's manual, it has a picture of where the oil should be applied. Only one or two drops!! It should probably be oiled frequently--about every 8 hours of sewing time. Pfaff probably sells a sewing machine oil for your machine. Just tell them your machine model and they should know what you need. Do NOT use 3-in-1, WD-40, cooking oil, or the old stinky brown stuff from grandma's sewing basket!
Feb 24, 2016 | Sewing Machines
I'm having difficulty with mt Janome 6400. The bobbin will suddenly shift and stall everything. I can remove the bobbin and actually pull the bobbin case back, and sometimes I can sew for aw
look in your sewing machine manual, see if it mentions oiling your sewing machine, if it doesn't then the sewing machine could be a self oiling from the factory,,self oiling mean the part were put in oil for a period of time and they won't need oiling, the more you sew then the oil will be released to oil the parts automaticly. sounds like you may need a new bobbin case, did the problem start before the machine was serviced or after?
Nov 04, 2014 | Sewing Machines
Do i need to oil my baby lock sewing machine?? Quiter's choice.
I cannot find a manual for this machine except at sew4less.com and the price is $14.95.
Contact Babylock to see if they will provide you with a download of the manual - http://www.babylock.com/contact-us/index.asp
If this is a mechanical machine, use sewing machine oil and the shuttle may be the only place it will need to be oil.
Apr 30, 2010 | Baby Lock BL1556
How and where to oil my 1780 white quilting machine.
You should contact a White sewing machine dealer. The manual does mention the machine needs regular cleaning and oiling, but provides no direction for oiling. Usually computerized machines are only oiled (one drop) on the race where the bobbin case rests. However, your dealer should be able to advise you.
Sep 29, 2009 | White Sewing 1780 Sewing Machine
Singer SEARS KENMORE 158 Sewing Machine Feed Dog Logo
64 people viewed this question
Top Singer Water Dispensing & Filtration Experts
ray gallant
Bill Boyd
Tom Chichester
Are you a Singer Water Dispensing and Filtration Expert? Answer questions, earn points and help others
