Question about Haier HLP23E Top Load Washer
Water leaking from bottom of machine
Water come out of machine from bottom directly
LG true steam inverter direct drive 9 kg f1479fds5 on a screen AE error what s happend
The AE error is indicative that there is a leak somewhere in the washer and it has triggered the flood protection device found at the bottom of the machine. What you should do is find out if there is indeed a leak. Try tilting it forward and find out if water will run out. If you can see water leaking from the water, call a repairman!
Jan 31, 2017 | LG Washing Machines
Water coming out from the bottom
check for ,cracked hoses and leaking water pump. position machine over a sheet of paper and see if the water is directly under tub . If so it will be a shaft seal that is leaking.
Aug 17, 2013 | Washing Machines
My washer makes a grinding noise and leaks out the bottom
washer makes a sqeeling noise where fan belt is attatched but only in one direction.could the machine need rebalancing?
Feb 21, 2013 | GE WBSR3140DW Top Load Washer
Water coming out of the bottom of the machine
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
Sep 27, 2012 | KitchenAid KHWS01PMT Front Load Washer
Water leaking from bottom of washer when in spin cycle
If it is a newer maytag made by whirlpool that would be a direct drive unit..if water is at the front of unit the pumps are known to leak on the direct drives///Need more info mod # to answer percisely
If I helped please vote...need more info please ask
Feb 04, 2011 | Maytag Washing Machines
There is water leaking from the bottom of the machine
Check out servicesunlimited they have full diagrams and parts.
Jun 25, 2010 | Gaggia Titanium Espresso Machine
Coffee maker leaking from bottom
I have had a few of these machines leak.
I pulled off the bottom and found Mr Coffee is using low quality tubing that melts or leaks where it attaches to the heater element that boils the water. I replaced the tubes with higher quality silicone tubing that I bought directly out of China on Ebay and the problem was solved.
Dec 26, 2008 | DeLonghi Caffe Nabucco BCO70...
Water leaking out the bottom of the door
You most likely need to make a small adjustment to the door. While the door is open push the bottom of the door towards the machine and pull the top of the door away from the machine, be careful not to go too far. that should take care of the leak. Before you do that make sure the water is coming out between the glass and the seal. I would remove the lower panel and make sure the seal doesn't have a small hole. You should see the seal leak from the inside. Hope this helps
Jan 13, 2008 | Frigidaire GLTF2940ES Front Load Washer
Haier HLP23E Top Load Washer Logo
46 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
