Question about Dell Studio Slim-Tower Desktop Computer
Power button wont work
Computer wont start up
Dell inspiron 1150 wont power up the power light flashes green and batery light flashes orange but the fans or any thing else wont work
You may have a burnt board or the input pin is bad, try wiggling the pin while it is plugged in to see if you can at least get the fans to start you obviously have a short of power in the power button area. You may want to try replacing the power button board for your model this may offer you a solution. If you take it in they can test it with a meter to make sure that this is the problem before a board issue is determined. It is difficult to diagnose this kind of things without the machine in front of me. My advice is to take it in and have the power investigated.
Just because the lighting on the battery is going and showing signs of life does not mean the power button is not bad or not getting the proper power to start the computer. It seems to me that the power button board is bad. Or the input cord pin may be shorted out and only supplying power to the mains but not the power button circuitry. Just a good guess!......John
May 11, 2012 | Dell Inspiron 1150 Notebook
I have a lenovo g460 laptop. working fine but suddenly wont start. says some windows files are a problem. the start up repaid does seem to work (although disk light flashing) and I cannot start in safe...
Welcome to Fixya
Looks like theres is a problem with the operating system already. You might need to restore the computer back to the factory state. Turn off the computer then press the button that sits beside the power button. Follow the on screen procedure to restore the computer.
Thank you for using Fixya!
Sep 27, 2011 | Lenovo G460 14" i5-480M 2.66GHz 4GB 500GB...
There is no power from the battery or the adapter and the laptop does not recognise the adapter is plugged in. there are no lights coming on and the power button is doing nothing
Your battery maybe out of charge. Thats why nothing happens when you press the power button. The battery may not be charging because the power cord might not be working. Try another power cord.
Try removing the battery and plugging the power cord and switching on the computer. If its the problem with the power cord the computer wont start. If it starts, the power cord is working fine.
Nov 18, 2010 | Acer Aspire 5920-6727 Notebook
Computer wont start acer aspire L-100
CPU overheated? When you cool it down it will start. You can check whether there are lots of dust on the CPU fan and the chase of the machine, they might block the air flow and overheat the CPU.
Jul 08, 2010 | Acer Aspire L100 PC Desktop
Emachine wont start
remove all external and internal peripherls.
example for external: mouse, monitor, keyboard, printer.
Internal: hard drive, memory modules, video cards, modem (if there's any), optical drive or dvd drives.
just leave the motherboard, power supply and processor intact, try turning on the computer with out those components mentioned. see if you get a beep sound before it turns off, but if not the most logical part that needs to be replaced on this type of problem is the power supply if that doesn't work the next thing to do is replace the motherboard. hope that helps
hit me back on the results. thanks!
May 25, 2009 | eMachines T6211 PC Desktop
Deskjet F2210 wont scan
Click start
Click programs
Click HP
Click HP support center
Click Scan.
Ths scan button on the deskjeyt itself wont work, but the scand command done directly in the computer does.
Apr 05, 2009 | HP Deskjet F2210 InkJet Printer
My computer wont turn on
Sound like 'classic' failing capacitor symptoms to me... RMA the power supply if you're able to, start scraping together some cash for either a rebuild (replace capacitors) if you can't OR purchase a NEW PSU
Once you get the system running... I would recommend you leave it turned on 24/7 as this will keep the failing capacitors at a static temperature (instead of the heating/cooling cycle) thus milking the last bit off life out of it while you secure a replacement unit.
Jan 15, 2009 | Cooler Master (RS-380PMSR/P) (RS380PMSRP)...
My computer wont start up
remove the battery and wait about 20 min and pulg it up with out the battery
Dec 12, 2008 | Dell Inspiron 5150 Notebook
My coputer wont start
Do you hear a whirring sound when you press your power button? Is that sound located toward the back of your computer? If so your power supply may be ok and your motherboard has failed. If you do not hear a whirring noise then your power supply has failed and you'll need a new unit. Take it in to a repair shop or replace it yourself.
Oct 14, 2008 | Computers & Internet
Dell Studio Slim-Tower Desktop Computer   Logo
14 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
