Question about Makita 9404 4'' x 24'' Belt Sander
Belts on my Makita beltsander keep ripping at the joint despite proper belt instalment
I have been sanding for a short period and my new belt ripped at the joint, this happened 4 times over. I do know how to install the belts, I am a cabinetmaker by trade and have been using Makita belt sanders for years!
rowdy45176
  • 2176 Answers
SOURCE: The belts on my Makita 9304 belt sander are wearing unevenly
check the wear plate on the bottom and also check the front roller for being out of round is where I would start. Let me know if doesnt help
Posted on Feb 18, 2009
  • 10865 Answers
SOURCE: Putting Sanding paper on makita sander
A makita power planer is just what it says, a planer. It has blades that spin at high speed and remove a thin layer of wood with each pass. The orbital sanding sheets go on another tool called an orbital sander. Write back if you find the sander and can not figure out how the sheets go on it.
Posted on May 02, 2009
heatman101
  • 43501 Answers
SOURCE: My Makita 9901 belt sander is used but very
There is a screw that changes the angle of the roller to change the tracking of the belt... this is very sensitive and probably if you are having trouble is more a reflection of the belt quality then the sander...try different belts before you toss the sander... I have had one for years and love it... although the belt tracking is tricky sometimes anss your have to keep after it...
The adjust ment is very touchy only turn it maybe 1/8 turn at a time...
heatman101
Posted on Aug 31, 2010
SOURCE: new rubber drive for makita 100 mm belt sander
WENT TO RUBBERMAN IN GEORGE AND FOR R20.00 THEY REPLACED THE RUBBER ON THE DRIVE WHEEL-BEATS PAQYING THE THOUSANDS FOR IMPORTED SPARES.G
Posted on Sep 30, 2010
pst4911
  • 41 Answers
SOURCE: my makita 4"X24" sander makes
http://www.ereplacementparts.com/makita-9404-belt-sander-parts-c-97_103_535.html
I would say you have a bearing going out ether on the motor this web address will take you to a good break down of the housing I would say you need a motor bearing it will also give you a parts # but if you have a bearing supplier somewhere ( I look in yellow pages for electrical motor repair) you might find the bearing for a cheaper price just remember to take the old one with you so you are sure to get the same size. I have found bearing and belts for my table saws are the same as for some clothes washers for about 1/2 the price as ordering from sears
good luck
Pat
Posted on Oct 29, 2010
I have a Makita belt sander,just replaced belt tensioner system including springs and roller but belt drive roller still keeps stopping on relatively light load even though the motor is running
very good trade tool
how quickly is it getting hot
slowing motor could be the cause
motor bushes and bearings can be replaced
did the motor drive belt under the cover get replaced
Jun 02, 2016 | Makita 9911 Compact Lightweight 3" X 18"...
I am looking for a drive belt for a mastercraft 3x21 beltsander. the belt says 120xL031. cant seem to find one anywhere.
The belt you can replace with a is simply any generic 3x21 belt. You can find them at your local hardware store or order them from a website like Home Depot, etc and have them shipped to your home. Here is a link to take you to Home Depot specifically for an 80 grit, but you can look for other grits as well. 3" is your width and 21" is the diameter of the belt you need.
Gyros 3 in 21 in 80 Grit Aluminum Oxide Sanding Belt 5 Pack 12 32180 5 The...
Feb 14, 2015 | Tools & Hardware - Others
Why does my serpentine belt keep breaking?
It sounds to me like one of the belt-driven accessories is stopping. Remove the belt and turn all of the accessory pulleys by hand, both slowly and quickly, in both directions. Any that does not turn smoothly, quietly and easily is suspect and that accessory should either be replaced entirely or have its bearings replaced (if practical). In my experience, the most common accessory to cause this problem is the power steering pump, but it could be any of them.
Mar 20, 2012 | Dayco 5061015 Serpentine Belt
The sanding belt on my Makita 9403 keeps breaking at the glued joint after only 5 minutes of use. Have fitted a new graphite pad, but this has not resolved the problem. Am using genuine Makita sanding...
They will do that if you install the belt in the wrong direction...
Check the arrows on the inside of the belt and make sure you are turning the belt in the right direction...
Otherwise check a different brand of belt...some of them out there are ****....
heatman101
Nov 22, 2010 | Garden
My Makita 9901 belt sander is used but very slightly and now is just frustrating to even use. What is the most common cause for tensioning roller to keep pulling the sanding belt over against the housing?...
heatman101
Aug 31, 2010 | Makita Tools & Hardware - Others
Beltsander
whats the problem ?belt comes off?
Jan 06, 2010 | Bosch 1274DVS 3" x 21" Belt Sander
The belt keeps slipping off the rollers
Generic comment:
There should be a knob on the side away from where you put the belt on to adjust the front roller. When properly adjusted, it should run true.
On the other hand, yours may be an auto adjusting. If this is the case, yours is sticking and probably needs cleaned. (though freshly released from the reconditioning shop, id exect it to operate properly). Id suggest you visit the Makita web site and look for a operator manual. Another resource for you to check is www.archive.org
You may have some recourse to the manufacture if you JUST got and it is not right. Might be worth a e-mail to them too.
Good luck with your new sander.
a
Oct 15, 2009 | Makita 9911R Reconditioned 3" X 18" Belt...
Main belt vibretes at 40mph and it rips off.
Obviously have to take a close look at pulley conditions & alignment, as well as tensioner. While the belt is off, check each pulley by trying to spin it for excessive resistance, and or movement, side to side, up & down, feel for grinding like indication bad/dry bearing. Try applying a little force in direction that belt would when it's on, as you rotate pulley, as it may only show or feel it when force applied. Remember, when you accelerate, crankshaft pulls harder on that belt & if tensioner isn't keeping proper tension on at all times due to partially seized or weak, it will allow belt to loosen up & bounce on opposite side from pulling.
Apr 04, 2009 | 1998 Chrysler Town & Country
New belts on drum sander shear off inside clip
Belt sander are very tempermentel and require a light machine oil (3-in-one) on the metal slides and Tension lever and springs to opperate properally, if not they will drive you nuts, it will make a big differance, a few drops will do ya, more it needed, to much will cause a reverse action and collect dust, clean areas before oiling with air preasure and fluids if needed to get rid of build up from wood dust
Jan 20, 2009 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
Makita 9404 4'' x 24'' Belt Sander Logo
57 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
