Question about LG 37LB1DA Television
Can not connect hdmi
Hdmi connections don't work
HDMI`S DON`T WORK ON VIZIO TV
The HDMI controller is bad. The easiest "work around" is to use the "Component" connectors instead. The only downside is you get no higher than 720P. However, most cable/satellite and _all_ antenna signals are only 720P anyway. Most people are only seeing 1080P when viewing Blu-Ray discs. Cheapest alternative is to buy an "HDMI to Component" converter, which will let you connect multiple HDMI connectors to one box, and then have one set of Component connectors coming out of the box. You select different "sources" on the box itself.
Mar 07, 2016 | Vizio Televison & Video
No Signal when HDMI connected with TV and cable box
Replace HDMI cable first, then check whether your box works on HDMI out. Try connecting box using other out (USB, VGA, DVI, DP, cable)
Apr 25, 2017 | Sony BRAVIA Televison & Video
How can I connect PS3 to ACER X110P Projector
does the projector have an HDMI port?
i would buy the cable that is HDMI from the PS3 (unless it has HDMI already)
HDMI converter (HDMI to DVI or VGA) typically don't work well because you are changing the signal from digital to analog through a cable. you want to use a cable that is the same on both ends.
Nov 09, 2012 | Acer Computers & Internet
Hdmi outlets on slyvania lc320slx don't work
you may need to upgrade the firmware....it seems the 1.5 version corrected for "no picture with certain devices connected with HDMI"
you can find it here
Here you can find the instructions for performing the Firmware upgrade.
Aug 31, 2012 | Sylvania LC320SLX 32 in. LCD TV
I own an acer aspire 5332 laptop, an don't know how to connect it to my hdmi television? what lead do i use? as a normal both ended hdmi lead won't work?? can you help me pleas, or to go somew
If your model does not have an HDMI out connector (the maual indicates not all models do have this, you can purchase an HDMI card for your PCI express slot and add the functionality to your laptop.
There are also plenty of USB to HDMI converters that can turn your USB port into an HDMI port.
Hope this helps
Apr 26, 2012 | Acer Aspire Computers & Internet
Picture has red tint when macbook air is connected through HDMI
I have exactly the same problem with my mac mini when I connect it to my Sony Bravia with an HDMI cable which works fine with my Apple TV. Sorry I don't have an answer yet!
Nov 10, 2011 | Dell W3707C 37 in. LCD Television
Only 1 hdmi outlet on TV . I have a high def cable box and a sony blue ray dvd player. How do I connect 2 hdmi cables fron the components to the tv?
Don't used the Blu Ray player on the tv HDMI out put hub.Used the connections for of the Blu Ray player connections by a S-Video cable for the video and the RCA component cable R,W for the connections for the audio out.The high Def.cable box will not work for high Def. this way,but the Blu Ray player will.
May 30, 2011 | Sony BRAVIA KDL-40S2400 40 in. LCD HDTV
How to tune in for blu ray dvd
You do not tune in your Bluray player but connect using an HDMI cable or Composite cable. If you have a HDMI cable connect the Bluray's HDMI out to the TV's HDMI in at the back and using the TV's remote switch the Input source to HDMI. You will see the image from the Bluray player in high definition.
If you don not have a HDMI cable connect the composite out of the Bluray player using the Yellow/Red/White cable to the TV's composite input ( same three color sockets ) and switch to AV input on the TV. Using this connection won't give you high definition image but will work OK.
Apr 23, 2011 | Sanyo DP32746 32 in. LCD Television
I am having connection issues with an LG 55lh40 television, a HD DVR from Directv, a PS3 and a DVD/VCR combo. The TV seems to be working good, but does not seem to be picking up an HDMI cable of any kind....
No picture
when connecting HDMI:
Check HDMI cable over version 1.3.
The HDMI cables don’t support HDMI version 1.3, it cause flickers or no screen
display. In this case use the latest cables that support HDMI version 1.3.
Feb 14, 2010 | Televison & Video
LG 37LB1DA Television Logo
18 people viewed this question
Computer Repairing
Computer Repairing
