Question about shaw.ca
No signal + snow on screen - shaw.ca
    Genius:
  • 1,552 Answers
If you have a "non-High-Definition" Shaw Digital Terminal, tune your TV to Channel 3.
If you are using "component-input/output" or "composite-input/output", use the "Source" (or "Input") button on your TV's remote control to select the correct "input".
Posted on Feb 24, 2015
Why no picture?
Probable power supply failure
Apr 14, 2016 | Insignia Televison & Video
Snow on screen
If blue-back option is OFF, it is normal to see snow on screen, when there is no RF signal. This is not a fault.
Aug 04, 2012 | Sharp 25J-S100 25" TV
The sound on my 95 hitachi bis screen tv works but there is just lines and snow on the screen, there is no color to the screen.
The tuner is bad, try directingthe signal to the Video input, and put the set in Video mode, you will also have a better picture,,use RCA cables from signal box to TV.
Aug 10, 2011 | Hitachi Televison & Video
Tfdvd1591 - screen has snow. It was working fine and I changed channels too high I think. the lcs settings has a channel number and I am not sure what that should be
This is actually a copy of the manual. When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components
Jan 16, 2011 | Coby Televison & Video
Screen suddenly went to complete snow no video or audio
Well the LG tv is not getting the cable signal.Unplug the cable box about an hour.Replug the box let the software to upgrade the cable box.The LG tv should get the signal back as normal.Not,than the LG tv Tuner board have problems it dead.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Apr 21, 2010 | LG 32LG30 32 in. LCD HDTV
Blue screen
it is not seeing a signal source.in the earlier days,"snow" would be evident but today the tuner signal lost results in a blue screen.check the cable signals and the cable box.
i would put cable from the wall directly into the set and see if there is a picture,and then check that it is not set to aux input with nothing connected
Aug 18, 2009 | Sansui DTV2760 27" TV
What can I do to fix the flipping of the screen from snow to prog
the tuner is getting a weak signal and that is why the vertical sync signal is weak and the picture is rolling .check the cable on the back
May 23, 2009 | Samsung Televison & Video
Repair Akai TV
the snow is just because of poor quality signal
the signal coupler which is in the tv might be bad or your dish needs to be reset cause of the wind
Mar 12, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Usuable signal/blue screen
No picture, just black screen
Check R3414, an SMD chip on the CRT board. There could be invisible bad solder joints
Noisy picture
Replace relay RY481 on S2 board
Picture int disappears leaving snow on screen
Resolder the Xtal in the tuner
Nov 23, 2007 | RCA 32V430T 32" TV
Tv problem
Your TV is telling you that the cable, antenna, or another input has no signal coming into it. When there is no signal, the set mutes itself to a blue screen to avoid your seeing "snow" on the screen. You need to check your connections. IF all are O.K., then your problem must be in the tuner or A-V input. Stargazer
Dec 17, 2006 | Durabrand DU1901 TV
shaw.ca Logo
67 people viewed this question
Top shaw.ca Computers & Internet Experts
David Payne
David Payne
Are you a shaw.ca Computer and Internet Expert? Answer questions, earn points and help others
