Question about Kitchen Ranges
Amana self clean oven lock light is flashing - Kitchen Ranges
SOURCE: Oven wont turn on.
I tried several times to get my oven to work and nothing seemed to help. After downloading the manual from this site, my husband locked and unlocked the oven door several times very hard and it knocked something in place and now my oven works. I hope it works for you.
Posted on Dec 08, 2007
  • 38 Answers
SOURCE: Cancelled self-clean, F9 code came up, door lock light flashing, can't use oven
HI,
your model number confirms that your range was manufactured by WCI (Frigidaire). although this doesn't help you now, it may help if parts are needed.
now, there is an indepth guide online to fixing this common problem and I would like you to go through it and see if it helps you solve your problem.
http://www.applianceaid.com/clean-lock.html
If you have found this site previously then I apologise, if you still need help, by all means post again and someone more qualified may help.
Hope this is of use to you ;)
Phil
Posted on Oct 28, 2008
  • 22 Answers
SOURCE: Self Cleaning light comes on and flashes when you turn on oven!
It sounds like you have a defective Oven control module. (TO8 Control) is the part that controls all oven functions including clean,clock,timed bake, ect. Item is easy to replace yourself.
Posted on Mar 30, 2009
SOURCE: Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Posted on May 25, 2009
SOURCE: how do I clean my amana gas self cleaning oven
I have an Amana self-cleaning oven, Model AGR5715QDQ. I can't find my manual - how do I start the process of cleaning? Elizabeth
Posted on Nov 22, 2009
How do I stop the door lock from flashing on my self cleaning oven
Hello Brian Pelletier, thanks for your inquiry!
I understand that you are having issues with your door not locking upon using the self-clean feature. It sounds like a possible issue with your EOC (Electronic Oven Control) or dock latch assembly. I would suggest unplugging your range if possible or flipping you breaker for ten minutes to perform reset. If the light continues to flash you may want to seek assistance from a professional for proper diagnosis and repair. -Matt
Oct 13, 2014 | Frigidaire 30 in. Electric Self-Clean Coil...
I inherited an older Amana Gas oven that is self
Here is an older manual with instructions on self clean and everything else. Hope it helps!
http://shop.amana.com/assets/pdfs/literature/30946503.PDF
Jan 29, 2010 | Ovens
Oven door latch does not lock - I was told part no longer available
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
May 07, 2009 | Amana ACF3355AS Gas Kitchen Range
Amana Oven Door won't open. Latch to lock it is broken.
After pressing Self Clean, Adjusting the Time and Pressing Start, the self cleaning cycle shows the # F57_ on the read-out. I tried to cancel and now the door opens, but I can't get the Bake to begin when I press Start. No matter what I press LOC flashes on and off, but the door is unlocked and the heat is off.
Please help!
Susan, PR
Apr 17, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana range ARG7800E Oven, Broiler and Self Clean will not ignite
heatman101
tti
Apr 07, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Unlocking Oven controls
According to the manufacturer's website you should only need to Press and hold the "Lock" key for 5 seconds. A single tone will sound and the "Loc" will disappear off the display.
This is the link to Whilpool's website and to the manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209761079.pdf
Thank you
Agent Matt
Go Ahead. Use Us.
Apr 07, 2008 | Amana ARGS7650SS Gas Kitchen Range
Amana oven not working and boiler also
Check the oven sensor it may be the problem. Also check the lock assembly. When in self clean does your bake come on too? It should come on with the broiler.
Dec 21, 2007 | Amana RanARG7302 Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
