Question about Danby Designer DAR1102W Refrigerator
DAR1102W Refrigerator leaking
Began leaking from underneath after having it for 4 years
Danby DAR1102W
make sure coils are back like they should be
Jun 24, 2012 | Danby Designer DAR1102W Refrigerator
JCD2389GT
WHAT IS WRONG WITH YOUR REFRIGERATOR?
small_4_1.jpg For a detailed Refrigerator illustration, click below.
redarrow.gif Side by Side
redarrow.gif Freezer on Top
redarrow.gif Freezer on Bottom
redarrow.gif Under counter
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Danby Designer All Fridge (no freezer) Model # DFF1776WE Water pooling underneath crisper drawers. Very full every couple of days. Then it leaks out the bottom door hinge. Not sure if drainholes are the...
Yes it is located in the refrigerator on the bottom in the back. I assume you know how to clear it, Hot water plus towel to soak up excess water should take several tries of very hot water until it clears. Good luck
May 26, 2011 | Danby Designer DAR1102W Refrigerator
On the inside refrigerator temperature knob is 1 the coolest or warmest temperature?
most often the lowest number is the warmest setting, and the highest number is the coldest setting.
Dec 10, 2010 | Danby Designer DAR1102W Refrigerator
Unit ices in a few days after defrosting and will not cool.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 16, 2010 | Danby Designer DAR1102W Refrigerator
I have an Amana side by side refrigerator model SXD225SW and the other day water began leaking from underneath the refrigerator. As the couple of days have worn on, it seems as though the amount of water...
Move the refrigerator out from the wall and look for the location of the leak.
Step 2
Check the side panels and the seals around the door for beads of "sweat." This could indicate a condensation problem.
Step 3
Check the floor. A puddle there could indicate a missing or cracked drip pan, or a leak in the water line that feeds your ice maker.
Step 4
Check for water seeping from the front of the freezer or the refrigerator. This could indicate your defrost drain is plugged or your ice maker is leaking.
Fixing a condensation problem
Step 1
Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely.
Step 2
Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets (see How to Fix a Refrigerator That Cools Poorly).
Step 3
If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls
Hope this helpout......
Aug 15, 2010 | Amana SXD524VW Side by Side Refrigerator
Water leaking on the floor
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in.
Good luck! :)
Vlad
First Choice Appliance
Jun 03, 2010 | Jenn-Air JCD2290HES Side by Side...
Self defrost freezer leaking water in refrigerator. can't find drain hose to see if it is plugged. been leaking for 2 weeks . had repairman here but did not correct the problem. any help would save this 4...
there should be a pan underneath to catch the condensate. backtrack the tube from there. it'll usually lead to underneath the evaporator (cold) coils on the inside.
Nov 12, 2009 | Magic Chef MCBR440 Compact Refrigerator
REFRIGERATOR MOTOR CONTINUES TO RUN AND WATER IS LEAKING.
heatman101
u
Mar 22, 2009 | Whirlpool ET8CHEXSQ Dryer
Danby Designer DAR1102W Refrigerator Logo
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
