Question about Hammering
How much grease do we put into the milwaukee demolition hammer when rebuilding it
4 Suggested Answers
jmgldsmth
  • 2005 Answers
SOURCE: Need manual for Hitachi Demolition Hammer
http://www.hitachipowertools.com/product/files/concrete_masonry/demolition_hammer/H65_OM.pdf
Posted on May 28, 2009
  • 142 Answers
SOURCE: Bosch demolition hammer oozing grease/oil.
Look around there for some O rings we have had this same problem with some of our Bosch hammer drills, and they usually replace a set of seals around the nose of the tool
Posted on Jul 06, 2009
rowdy45176
  • 2176 Answers
SOURCE: dewalt demolition hammer stopped hammering.
could be a few problems, the striker could be stuck from debris or the ram might be hydraulically locked. they make a rebuild kit for this tool if you are mechanically inclined. I would suggest first going to their site and downloading a parts breakdown and there you will find what is involved and the parts listing. It is "dewaltservicenet.com" and on the left hand side type in your model number and then follow the links to download this. Let me know if you need more assistance.
Posted on Apr 23, 2011
What type of oil shall be used in makita hm1304 demolition hammer?
You require Hammer Grease, All good tool shops should have grease to suit. see link below:-
Hammer Grease 90582 for Makita Power Tool eReplacement Parts
Feb 11, 2016 | Makita Hammering
How to put oil in Hitachi H65
OIL ?? I think Hitachi has always a yellow grease lubrication
hitachi grease demolition hammer Google zoeken never seen heart of oil in Hitachi demolitions. but there could be models in your Country thats new for me .
Otherwise BOSCH HILTI and the one and only brand DUSS demolition hammers and also a few brands of Chinese hammers need oil lubrication . an expensive sinc-free hydraulic oil the same as used in some pressure washers life lasting oil but for HItachi look at the link for the grease 2 tubes a enough . good luck and dont forget the piston pin to replace with a new not only the gaskets and o-rings and also the oil and dirt seals on the front where the striking pin is that must be absolutely not air leaking because all your work burns in a few months again out . you can start all-over again.
May 15, 2014 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
How to repair bosh 11316evs
Purchase a service kit # 1-617-000-190
This will have all the normal wear parts including brushes & new grease.
This is a fairly easy hammer to rebuild - make sure you thoroughly clean all the parts, install new rings & grease - the kit comes with a parts breakdown to help. Service Pack 1617000190 for Bosch Power Tool eReplacement Parts
Apr 15, 2014 | Bosch SDS - max Demolition Hammer 11316EVS
What grease do you use for a makita demolition hammer
MAKITA HAMMER DRILL GREASE 30G (181490-7) or for the older HM models Hammer grease Makita P-08361
Nov 05, 2012 | Makita Hammering
Need diagram for kango 900 concrete hammer drill
Hi Vicki
Is it the old all silver one or the new one with the red motor housing?
May 19, 2012 | Milwaukee Tool Hammering
A friend of mine recently purchased a Makita HM1500B demo hammer. It came without grease. How much grease is required to initially fill the case? Is there a different type of grease that can be used?
If this was a new unit, it comes with the proper amount already in the gearcase. You might need some for the hammer bits (a small amount of lithium grease) but other than that until the tool needs repaired you should not have to add any.
May 09, 2011 | Makita HM1500B 42 Lb. Demolition Hammer
Kango 900 hammer:\r\nDon't know how to greace the
Milwaukee K900K or the English Kango 900K Blue old or Red some younger handle it differs very much English Kango was using a thick brown grease in 2 chrome colored plastic bags . the Milwaukee K900K has a lubrication grease also not oil but be aware of the operating hours i f you have a K900K model from Brand Milwaukee tools replace also a service kit and the bearings on the armature is important also Its neccesary to protect you from damage
if you have a English Kango its hard and expensive to get a spare parts and most times the tools are worn in the front of the chisel stroke bolds do not get right close and the piston pins are worn it was a good tool about 20 years ago i have serviced much of them . but the first thing thats important that its air-tight in front of the chisel and everywhere thats having a mechanic/pneumatic duty
Milwaukee Services and fill k900k with (IMPORTANT) the right number
Jun 05, 2010 | Electric Demolition Jackhammer
I have a Kango 950 and it doesn't work properly. When it is plugged in the motor works fine but the chisel bit does not move up and down or even vibrate.
Sounds like lubrication. Used special grease only. May have broken cam. Hammer will run like you say if no load is placed on drill tip. Test it on a rock. Probable rebuild adviseable.
Oct 12, 2009 | Hammering
Jul 05, 2009 | Bosch Hammering
Hammering Logo
46 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
