Question about 533 2way Security Remote Start System
My python remote starter 533 starts my truck every 24 hour that symbol 24display icon#10 how do I get my truck out of this mode
4 Suggested Answers
  • 68 Answers
SOURCE: I had the brain of my python remote starter/alarm
have it replaced again, that sucks dude
Posted on Jan 24, 2010
slick42371
  • 42 Answers
SOURCE: Python 1600 XP Remote Starter my
You have the 24 hr timer on and you just have to press the lock and remote start buttons at the same time.
Posted on Feb 02, 2011
logosc75
  • 625 Answers
SOURCE: How can I find a users guide for a Python 473P remote starter?
473P is the part number of the remote. 473P is the original remote for a Python1200XP alarm. I have the users guide.
Posted on Aug 21, 2012
Python car starter
Can you remove the python box without removing the wiring? That'd be a pretty definitive way of determining if the relays inside the python box are bad. On another note, this sounds like an ignition switch issue, the python box could just be coincidental.
Sorry, not much help... but see if you can eliminate the python box. That's the diagnostic process with electrical is to remove possible causes and record the results. Next, you might consider unplugging the wire harness from the ignition switch... or remove the wire harness that leads up the steering column.
Oct 16, 2013 | Vehicle Parts & Accessories
Remote start python 533 attempts to start the car, shuts off, then on a again, does it 3 times, then stops
There are three possibilities for the situation you are describing especially if the vehicle has been cold for a while. The first possible cause occurs when the smart tach feature is used. In this case, the 533 is not receiving the proper signal from the vehicle that shows the engine is running. The remedy for this problem is to connect the tach wire from the 533 a proper tach source. The other two causes occur when the smart tach feature is not used and the tach wire is connected. If the tach wire is not connected to a good source for the tach signal in which case the wiring will need to be corrected. Otherwise, the tach signal will need to be relearned.
Jan 17, 2013 | 533 2way Security Remote Start System
I need to reset my remote start. My car is starting every three hours
Your remote starter is in timer mode. Pressing the lock and unlock buttons simultaneouly activates the timer mode. When you activate the timer mode the vehicle automatically starts every three(3) hours and runs the preset runtime for a maximum of six(6) starts.
You can cancel the timer mode by starting the vehicle with the key. If the timer mode is a problem then apparently you are setting the timer mode everyday.
Sep 30, 2012 | 4103P Python 413 Remote Start System with...
Python 1400xp installed by circuit city on a 2004 chevy monte carlo. The car works fine but every now and then the car will not start with the remote or with the key, it takes 10- 30 mins to finally...
check your starter they act up like that, when it will not start if you could try to hit it with a hammer, pipe anything you can not on the solenoid but on the body of the starter if it start up you know that is your problem.
Sep 15, 2017 | DEI Python 1400XP Remote Start/Keyless...
Remote strater is in valet mode and i do not know how to get it out of valet made.
Try these two possible solutions
Press and hold valet button for 10 seconds. Release. LED should go out.
or
Insert key into ignition. Turn to on position (do not turn on car). Press and hold valet button for 10 seconds. Release. LED should go our
Jan 04, 2011 | 533 2way Security Remote Start System
Python 1600 XP Remote Starter my car starts at 1 pm daily automatically. How do I remove this timer on this remote starter
Dec 23, 2010 | 1600XP Security/Remote Start System
Python ce0890 FCC ID EZSDET474P RPN 473P 266 CODES. How do i reset this devise? The battery is good
While our Dodge ram truck sits - the horn starts blowing. We think it has to do with the remote and the security. We have the Python CE0890 remote starter - it is a few years old.
Dec 06, 2010 | 426P 460HP Security System - 426P
533 2way Security  Remote Start System Logo
29 people viewed this question
Top Python Vehicle Parts & Accessories Experts
rjivaro
Kevin Daniels
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
