Question about Kuuma Products Kuu 83722 Stow N Go Bbq Grill
Regulator is not woking right - Kuuma Products Kuu 83722 Stow N Go Bbq Grill
Fix tv takes to long to on
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jan 09, 2016 | Televison & Video
I have a bush TV model led24970dvdfhdt last night I put it in sleep mode as normal I woke up this morning and the standby button isn't even on it will not turn on and I've tried using a different socket...
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Jan 26, 2015 | Bush Televison & Video
Cadillac window repair
Try changing window switches from known good door. Make sure fuses are good!
Mar 07, 2014 | Cars & Trucks
Tcl l32m19 tv wont turn on woke up the other day and the light on the front was not on
Power supply regulator section [mains] to your TV should be troubleshooted. This is a skilled work.
Jun 26, 2012 | TCL Televison & Video
Lg 50PG20 IS MAKING A CLICKING NOISE AND WONT COME ON
Hello
Check the power supply regulator board for the fault.
Mar 03, 2012 | LG 50PG20 50 in. Plasma HDTV
Have power but not picture or sound
check the power regulator at power supply and filter cap
Jul 02, 2009 | Hitachi 51F500 51" Rear Projection...
Passage window
Sounds like the window regulator is messing up. See if you can take the panel off and look inside with a light and mirror.
Aug 05, 2008 | 1991 Buick Skylark
VW jetta 1996 power window not working
Take car to auto glass place.. Sounds like window regulator .. Motor working but gear is stripped
Jun 28, 2008 | 1996 Volkswagen Jetta
Kuuma Products Kuu 83722 Stow N Go Bbq Grill Logo
61 people viewed this question
Top Kuuma Products Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Kuuma Products Grilling Expert? Answer questions, earn points and help others
