Question about Breville BKC700XL Stainless Steel
Breville BKC700XL wont turn on - Breville BKC700XL Stainless Steel
Keurig troubleshooting
the switch mechonisum is defaulted in side the back panel.it can be inspected to make sure contact is being maid by the power light on the frthe unit
May 01, 2013 | Breville BKC700XL Stainless Steel
Would not power on
then you arnt getting power to the unit at all ! plug somthing ealse in the same w plug u are useing
Water not coming out. How do I clean the machine?
The Instruction Booklet for the Breville Gourmet Single Cup Brewer for the BKC600XL / BKC700XL can be found here:
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/Files/Keurig%20Brewer%20Manuals/Breville_BKC700XL.ashx
The booklet has an extensive section on cleaning.
Mar 12, 2011 | Breville BKC700XL Stainless Steel
I used the filter with my own coffee and now it is clogged. How do I fix it?
The Instruction Booklet for the Breville Gourmet Single Cup Brewer BKC600XL / BKC700XL can be found here:
See Page 32 for Troubleshooting. You may need to unclog the Exit Needle and run a cleansing brew.
Mar 06, 2011 | Breville BKC700XL Stainless Steel
When we push brw, the water comes out the bottom.. where can w get a manual for instruction usuage.
Please do not attempt to use the machine.
If water is leaking it could cause electrical shock, or further damage the machine.
In this case it is best to contact Breville customer support.
USA
1-866-BREVILLE (1-866-273-8455) 8am to 5pm Pacific Time
Canada
Mar 03, 2011 | Breville BKC700XL Stainless Steel
Can't find my manual. How do I clean it?
http://www.scribd.com/doc/21061955/Breville-BKC700XL-Manual
Found your manual....Click or paste the above link to the site with it! If you cannot find what you are looking for inside manual, run down to the nearest home store or grocery and purchase descaling solution and follow directions for use from the back of the descaling container. Most machines require frequent descaling (once every 3 months) depending on your water quality. Hope this helps!
Mar 01, 2011 | Breville BKC700XL Stainless Steel
Missing the instruction manual for a breville bxc700xl coffee maker just purchased from bed, bath and beyond. Any help?
You can visit the Breville Support website for the BKC-700XL. The owner's manual and quick start guide are available for download (PDF format) or on-line perusal.
http://brevilleusasupport.com/product/bkc700xl
May 01, 2010 | Breville BKC700XL Stainless Steel
Breville BKC700XL Stainless Steel Logo
65 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
