Question about Candy CDC266 Dryer
Drum not turnig round and can smell burning - Candy CDC266 Dryer
I was drying my tennis shoes in a pillow case. The shoes pillow case and 3 towels were in the dryer, I had a smell like belt burning turned it off immediately. LG Stackable Dryer.
I'd think unlikely to be belt, as that is only a drive connection. Remove back panel and take a look at the pulley. It might be the casting off center
Jan 11, 2018 | LG Dryers
LG WM 0642 HW Direct Drive Making a thumping sound when spinning and smells like burned rubber. Smoke coming out of durm when front load door was opened.
Hi Paul.
What you're describing is probably the inner drum rubbing on the door seal.
It could be because the rear bearing assembly has collapsed or because the drum is distorted.
Turn the drum slowly by hand and see if the gap between the rim of the drum and the rubber seal stays the same. This will tell you if the drum is 'round' or bent out of shape.
Alternatively, if the drum flops up and down inside the outer drum it would be because of bearing collapse
Either of these situations would require a service visit and parts.
Get a quote...
Good luck.
Nomess
Jan 11, 2015 | LG Washing Machines
Kenmore elite front load dryer squeaking and burning smell
you have a bearing in the drum support that has frozen and now the rubber wheel is burning up. The bearing needs to be replaced ASAP. You could damage the dryer if you continue to use it.
Feb 16, 2014 | Dryers
Frigidaire gallery dryer
Possible lint blowing around on the heater coil. That burning smell is like paper burning. Get the dryer cleaned.
Make sure there is nothing sticking to the inside of the drum from previous drying.
Oct 17, 2013 | Dryers
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
Drum not going round,burning smell when it started, when started it again it clanged really loud then stopped
belt and possible drum rollers:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 16, 2011 | Samsung DV218AEW Electric Dryer
Whirlpool Duet dryer - "burn marks", "out of round" drum
It's not really BURN marks - it is the adhesive used to affix the felt. You can substitute for silicone to remedy this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2009 | Kenmore Elite 45986 Front Load Washer
Hotpiont washing machine
first check if belt from motor to drum is on, then check to see if motor is running. If not, there maybe a fuse link or fuse that needs replacement. The last time you used did you smell burning, if so could be your motor is gone.
Apr 03, 2008 | Hotpoint Aquarius WD63 Front Load...
Candy CDC266 Dryer Logo
35 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Eddie Dalton
Eddie Dalton
Are you a Candy Dryer Expert? Answer questions, earn points and help others
