Question about Kitchen Selectives CM-202 Coffee Maker
Replacing door and basket - Kitchen Selectives CM-202 Coffee Maker
Door doesn't shut properly to start dishwasher, have to push door to work but stops if you let go
The machine will not function if the door is not fully closed. The locking/latching mechanism for the door probably needs to be adjusted or replaced if faulty.
Also make sure there is nothing inside the dishwasher that is fouling the door (like a basket rack that is not fully in position) and is not allowing the door to fully shut. Pull the baskets out of the machine and check inside as well.
Dec 20, 2015 | Dishwashers
Filter basket door opens during coffee making.
sounds like there is a bad relay, that is shorting out, and releasing the filter basket accidentally. Also, check to make sure that there is nothing blocking the latch that holds the filter basket in place.
Feb 05, 2008 | Cuisinart Thermal DGB-600 Grinder
Maytag 2000 drains all water and spins but spins slow
two things, first one is could be the r-11 resister on main board burned or a tub bearing . check the main board inside touch panel. on it is a resister that tells computer door lock is or is not latched door lock light may be lit but computer indicates not and will not advance to max spin. if resister is burned and board is replaced be sure that you replace the wax motor door lock motor as well. if you don't replace locking motor you risk burning out new board again. tub bearing is easy to find out. just lift basket at top with finger and feel for vertical movement of basket alone,"slop" or "movement up/down. if so then replace the rear tub shell and spinner for basket . hope this helps.
Apr 18, 2014 | Maytag Washing Machines
Basket rubs on door boot seal.
Be sure both lower and upper halves are correctly connect together
May 01, 2017 | Frigidaire Washing Machines
Basket doesn't spin when emptying wash water
remove door switch and tape the wires together, if it works fine now. replace door switch!
Jan 11, 2010 | Kenmore Washing Machines
My refrigerator is beeping and the door appears to be closed.
That red basket with a drip coming from it indicates your WATER FILTER needs replacement. That could explain your beeping as well. You need to replace the filter and RESET the alarm.
Jun 04, 2009 | Samsung RF265AA Bottom Freezer French Door...
Kenmore HE3 Front Loader Washing Machine tumbler
The metal basket (inner basket) has a broken spider (these are the support brackets that hold the basket to the bearing shaft). The inner basket will need to be replaced and the front and rear shell of the drum may also need to be replaced depending if any other damage has been done. It's a big job, about 2 hours for a good tech.
Feb 19, 2009 | Kenmore Elite 45986 Front Load Washer
Door spring came off filter basket door on Krups FME4 coffee mak
yhere should be a little post th spring goes on in the vack of the basket ...out in pkace hold untill in place
Dec 10, 2008 | Krups FME4 Coffee Maker
How do I put the spring back in that holds the door shut.
The replacement basket costs around $6.00 - don't fiddle with it, just a buy a replacement part from Cuisinart's website.
Nov 24, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Kenmore Elite ET3
The plastic casing (tub shell) around the stainless spin basket should not become worn unless the spin basket is hitting the outer shell. From my past experience, this is usually caused by a cracked or broken spin basket support (spider) arm on the back of the spin basket, or a shot tub bearing (which is also behind the spin basket). The bearing is actually part of the rear tub shell and is molded into the plastic. It cannot be replaced separately and requires the replacmeent of the shell.
If the spin basket supports become broken, the basket becomes off balance and rubs against the outer shell. This results in excessive vibration, which may be the reason why the support shocks were broken. No...this is not normally expected. Unfortnately, this is not a simple or inexpensive repair, either. If you have a service plan, or warranty coverage, I would recommend pursuing that as a repair option. If you wish to repair this yourself, I can post a link for you to follow, but it is expensive. This will usually require the replacement of the following parts:
Spin Basket
Rear Tub Shell (if bearing is bad)
Front Tub Shell (if spin basket caused significant damage)
Support Shocks (I would recommend replacing all 4)
Optional:
Drive Belt Pulley (can become warped or bent)
Drive Belt (if showing signs of wear)
Rubber Door Bellow (if vibration as caused damage to the rubber)
You can go to searspartsdirect.com and type in your model number to get prices for everything if you like. Everything can be found under the "Tub and Basket Parts" heading, with the exception of the rubber door bellow. It can be located under the "Door and Latch Parts" heading.
I know none of this sounds like positive news, but I do hope you find some of this information helpful. Let me know if you need further assistance.
Aug 20, 2008 | Kenmore Elite 45986 Front Load Washer
Coffee Makers & Espresso Machines Logo
18 people viewed this question
Top Kitchen Selectives Coffee Makers & Espresso Machines Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Don A
Don A
Are you a Kitchen Selectives Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
