Question about Style Selections Euro Style 24-in x 17-in Espresso Belly Bowl Single S
The fiberboard is damaged
Cabinet doors are deteriorating
What are the different types of cabinet doors?
wikipedia provides a good explanation, quoted below:
Frames
. In the U.S. solid wood frame and panel construction, using either mortise and tenon or cope and stick jointed frames, is traditional, with maple, cherry, oak, birch, and hickory among the most commonly used species. Mortise-and-tenon frames, with their greater strength and permanence, are more costly to produce and less commonly used as compared to cope-and-stick frames. As an alternative, miter joint frames, which may be identifiable by face-surface relief that follows continuously around the frame, have become popular. Miter-jointed frames typically employ embedded metal fasteners to secure frames elements (stiles and rails) cut at a 45 angle. Captured within frames, panels may be either solid or veneered engineered wood (either particle board or medium density fiberboard). Laminates, including those designed to resemble hardwood, can typically be identified by a more rounded appearance associated with the minimum bending radii necessarily entailed by the manufacturing process of applying laminate to an underlying substrate. By comparison, solid surfaces, and solid hardwoods in particular, can be milled with more sharply defined corners, edges, or grooves on either a panel or frame.
  • Panels. Panels used in frame-and-panel kitchen cabinet doors may be fashioned either of solid wood or covered by paint, veneer, or laminate in which case they are fashioned of engineered wood. The panels are typically not fastened with glue or nails but rather "float" within the frame to accommodate seasonal expansion or contraction of the wood frame.
  • Solid-door construction. Doors may be fabricated of solid material, either engineered wood (particle board or medium-density fiberboard, but not typically plywood) or solid wood. Engineered wood panels may either be used as slabs or may be shaped to resemble frame-and-panel construction. In either case, engineered wood panels are generally painted, veneered, or laminated. Solid wood panels are typically formed of multiple boards of the selected wood species, jointed together using glue and may either be painted or finished. Solid wood construction offers the possibility of refinishing in case of damage or wear.
  • Decorative panels. Cabinet doors panels can be used decoratively on cabinet sides, where exposed, for a more finished appearance.
  • Glass door construction options. Doors may have glass windows constructed of muntins and mullions holding glass panels (as in exterior windows). Other designs either mimic the divided-light look of muntins and mullions with overlays, or may dispense with them altogether. Cabinets using glass doors sometimes use glass shelves and interior lighting from the top of a cabinet. A glass shelf allows light to reach throughout a cabinet. For a special display effect, the interior rear of a cabinet may be covered with a mirrors to further distribute light.
Jan 30, 2013 | Hardware & Accessories
Tip
Sink Cabinet Replacement Bottom
IF your sink cabinet bottom is water damaged and in need of a replacement, this video gives step-by-step how to information for fixing it. This video was created by a cabinet professional who specializes in fixing Formica kitchen cabinets.
It is very informative for the person who likes to do it yourself" when it comes to repairing things around the home.
Tools and materials needed:
Saber saw
Diagonal cutters
Hammer
New sink cabinet bottom
Caulking
Caulk gun
Clorox Bleach
Three Support Struts
L-brackets
Finish nails
How to do the Repair:
Take the doors of the kitchen or bathroom cabinet off.
Remove the water damaged sink bottom by cutting it in half from front to back. You may need to use the hammer at this point. Just be extremely careful to not damage the plumbing.
Break off the staples with the diagonal cutters.
Clean the mold with the Clorox Bleach.
Install the struts designed to support the new sink cabinet bottom. Use L-brackets if necessary for attaching the center piece.
Install the new sink cabinet bottom replacement board. Attach it with finish nails.
Clean the inside of the kitchen or bathroom vanity cabinet.
Caulk all interior areas of the sink cabinet bottom.
Replace the doors.
Every sink cabinet is built differently. Make sure to examine how the cupboard was built to determine the best method for replacing the bottom of the cabinet. If you have a center style, you will need to cut it out and reinstall it using L-brackets.
on May 26, 2010 | Home
Dishwasher leaking
Hello - Make sure that dishwasher is level; if not, water can leak over the front lower baffle in the door. Look along the cabinet and see if the dishwasher is even with the cabinet. Another possibly could be that the dishwasher has a poor or damaged door gasket. If it is not sealing properly, it may need replacing.
Dec 08, 2012 | Frigidaire Dishwashers
I have a 2004 GE Monogram zisw420dmc refer. There are often small drips on the floor under the lower left and right corners of the freezer door. The fiberboard and stainless door cover have become damaged...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 23, 2011 | GE Monogram Side by Side Refrigerator
Door springs on Fisher & Paykel 920 dishwasher not working at all .How can they be replaced?
Hi - heres the instructions for you - have fun.....
Removal of Cabinet
(Do not use decorative panel to move the machine)
1. Isolate power supply.
2. Remove service and decorative panels (refer Section 6.1).
3. Ease machine forward for all round access. Be careful not to damage floor coverings.
4. Remove two screws from bottom sides of cabinet rear.
5. Remove the top screws on left and right hand sides of the cabinet rear.
6. Remove two screws securing the rear bottom panel.
7. Remove five screws securing the stainless steel frame to cabinet wrapper at front of machine. These are located behind the sound gasket and service panel.
8. Withdraw the cabinet assembly away from the machine.
Refitting: Refit in reverse manner. Fitting the top centre screw in the cabinet wrapper first, makes fitting the cabinet easier.
6.9 Removal of Door Tension Springs
Location: The door tension springs are located either side of the machine and are
fitted to the chassis base and door quadrants by means of the end hooks of
these springs.
After isolating the machine from the power supply:
1. Ease machine forward for all round access.
2. Remove service panel (Refer Section 6.1).
3. Remove two screws in the cabinet wrapper exposed by the Service Panel.
4. Remove the springs from the quadrants and the chassis base using pliers.
6.10 Removal of Hinge Assemblies
(Do not use decorative panel to move machine)
Location: The hinge assemblies are located either side of the door and retained by means of two rivets on each side to the inner door panel.
1. Remove service & decorative panels (refer Section 6.1).
2. Remove outer door panel (refer Section 6.2).
3. Remove cabinet (refer Section 6.7).
4. Remove door tension springs (refer Section 6.8).
5. Remove quadrant grommets.
6. Open door fully and drill out the two rivets from the hinge assembly on inner door panel.
7. Hinge assembly can now be removed from inner door and cabinet.
Note: Hinges should be replaced one at a time. Repeat procedure six and seven for other hinge. Hinge guide quadrants can now be removed by depressing sides and pulling free of slot if need be.
Refitting: Refit in reverse manner using 3/16 monal rivets to secure the hinges to the inner door.
Aug 10, 2011 | Fisher and Paykel 24 in. DS603H SS...
My Kenmore elite Freezer runs quite alot, and the fan continues to run even when the door is opened...what is wrong?
Sounds like the seal around the door is damaged or deteriorating and needs to be replaced to make a tight seal. ~Denise
Jul 04, 2011 | Kitchen Ranges
Have a ge microwave jes1289sk01 and it is sparking from behind the small fiberboard just inside the right side of the interior of unit. I removed fiberboard and sparking stopped. Unit still heats. do I...
That small card prevents food particles from entering Magnatron but allows RF energy to pass through. The corrosion mentioned is the result of the arcing. Just replace that protector. It will be specific to that brand and model.
Nov 14, 2017 | Microwave Ovens
I have a bathroom cabinet door that came off and now I can't get the screws to stay in as the inside of the cabinet is so damaged and wood filler does not work , even glue will not hold this door back on...
Buy a dowel pin the size of the hole in the cabnet then use carpenters glue to glue the dowel pin in place where the old hole was make sure it is a good tight fit. Next saw off the dowel pin and let set over night then drill a strating hole in the dowel pin and reinstall the door works like a chanp. Hope this helps.
Sep 28, 2009 | Duravit 6130 Starck 1.2.3 Vanity Unit w/ 2...
1997 Nissan pickup
start with 2 screws under horizontal part of door grip, third one up high-- then remove window handle(if no power windows. then underneath the inside part of little door release pocket there is a plactic- 'cup another screw behind there. then it becomes a prying effort. There are about six to eight plastic 'christmas tree' shaped tabs that are along the bottom rail of the door and scattered throughout the middle. Be careful when prying the weak fiberboard away from metal. or the base of the 'tree' will rip throught the fiberboard and not be as effective when you replace them back in. (it is not a fatal mistake but one that I failed at miseably when first removing the panel.
start at the outside bottom corner with two long srewdrivers. one to slightly seperate the metal and press board then use other to help pull the 'bushy' part of the xmas tree out of the metal part of the door.
Apr 06, 2009 | 1997 Nissan Pickup
We have a GE Spacemaker Microwave installtion issues
You need to have studs where the installation instructions specify them.
If they are not there, they will need to be added.
With the weight of these units, proper support is critical, and drywall anchors are not at all sufficient.
Nov 22, 2008 | Microwave Ovens
Style Selections Euro Style 24-in x 17-in Espresso Belly Bowl Single S Logo
190 people viewed this question
Top Style Selections Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Style Selections Health and Beauty Expert? Answer questions, earn points and help others
