Question about Garden
Where does gear shift cable attach - Garden
    Master:
  • 755 Answers
On what , there should be a place you can see
Posted on Feb 03, 2015
What do I have to take apart to replace floor shift gear selector cable for bf falcon
HI TERRY, PLEASE FIND ATTACHED PIC AND INSTRUCTIONS
REGARDS
RAMON HEWITT
REMOVAL AND INSTALLATION (Continued)
Gear Shift - Floor Mounted
Removal
1. Raise the vehicle and disconnect the transmission
shift cable from the lower selector lever.
2. Disconnect the four nuts that attach the housing 6. Remove the whole floor shift housing by lifting
to the floorpan. vertically
Installation
1. To install the floor shift housing to the floorpan
reverse the above instructions in order 6, 5, 4.
2. Place the selector lever in the 'P' position.
3. Raise the vehicle.
4. Reconnect the four nuts that attach the housing to
the floorpan.
5. Install the shift cable back onto the lower selector
lever.
6. Tighten the lock nut to the required torque to 28
Nm.
7. Lower the vehicle and check transmission
operation in each selector lever detent position.
3. Lower the vehicle. 8. Check that the mode light functions correctly. For
4. Remove the centre console (Refer to section further information, refer to Section 307-05.
307-05).
5. Detach the back light bulb/wiring.
BF00006
I6 Floor mount shift components
Jan 12, 2015 | Cars & Trucks
Is there something under the dash at my steering column that could cause my truck not to shift gears?
could be the shift interlock cable not attach
try this test ;; ignition key on push brake pedal do you hear a click sound. solenoid will pull on cable to unlock shifter but if the cable is not attach it will still lock
Oct 07, 2013 | GMC Cars & Trucks
How difficult is it to change the shifter cable
Take the rubber boot off the gear shift inside the vehicle and lift it up, exposing the area where the gear shift and the transmission connect.
Look for the shift cable and the shifting arm. A single bolt and nut connect the shift cable and shift arm.
Twist the nut connecting the gear shift and the transmission. Use a socket wrench and remove the gear shift. Use an open-end wrench to loosen the nut holding the shift cable and the shift arm together.
Slide off the sleeve on the shift cable and loosen the shift cable at the other end with an open-end wrench. Both ends of the shifting cable attach to the shifting arm in different locations.
5
Hitch the new shift cable to the 2 anchor points on the shift arm using the same bolts and nuts. Reconnect the gear shift to the transmission and push the rubber boot back into place around the gear shift inside the car.
6
Test the functionality of the shifting cable by moving the gear shift in and out of gear.
Jan 03, 2013 | Saturn Cars & Trucks
My 1993 Gmc Sierra 2500 automatic first gear shifts hard also from park to drive others gears are smooth i have overdrive
The gear shift lever indicators tell you what gear you have an automatic transmission in on your vehicle. The shift solenoid tells the transmission when to shift gears and what gear to shift into. Newer model automatic transmissions have electronic shift solenoids that are activated and change gears based on the speed the vehicle is traveling. Troubleshooting either one of these transmission components is relatively easy if you know a little about automobile mechanics. With the right tools, you can determine whether the transmission shift solenoid is having a problem. Gear shift indicator problems can be determined simply by moving the gears into their designated position.
Transmission Shift Solenoid
  • 1 Raise each corner of the vehicle up with the car jack and place jack stands under the frame. Make sure the car is raised high enough so you can work under the car freely.
  • 2 Slide the drain pan under the transmission fluid drain plug. Remove the drain plug with a ratchet and socket, and let all the fluid drain out of the transmission. Remove the transmission pan bolts with a ratchet and socket. Pull the pan away from the bottom of the transmission, revealing the transmission shift solenoid.
  • 3 Wipe off the shift solenoid with a shop towel. Disconnect one of the two plugs that attaches to the shift solenoid. Turn the knob on the volt meter to the ohms setting, so resistance can be measured. Set the volt meter on 200.
  • 4 Take the black lead of the volt meter and touch the negative battery terminal wire. Take the red lead of volt meter and slide the tip into the terminal plug you just disconnected from the shift solenoid. Look at the reading you get on the digital display of your volt meter. Determine if the reading is between 12 and 25. Readings below 12 or above 25 tell you that the shift solenoid is not working. Reattach the plug to the shift solenoid and pull the second plug attached to the solenoid. Perform the same procedures on this plug wire. Replace the transmission shift solenoid after determining it is bad.
Gear Shift Indicator
  • 1 Move the gear shift into the desired gear. Look at the gear labels and the arrow, or other indicator, to see if the gear shift indicator lines up with the selected gear.
  • 2 Move the gear lever to another gear and look to see if the indicator lines up with the selected gear. Misalignment of the arrow will tell you if there is a problem. Moving the gear shift to "neutral" but having the indicator show the transmission is in "drive" tells you the gear shift indicator is not working properly.
  • 3 Try each gear position to determine how much misalignment is in the indicator. Slide under the car and check for a loose gear shift cable. Check all the gear shift cable connections to ensure they are all tight and are not missing. Tighten any loose gear shift cable clamps or bolts. Replace the gear shift cable if you find that this is causing the misalignment with the gear shift indicator.
Feb 02, 2012 | 1993 GMC Sierra
Gear shift stuck
Hi Ray, The advise above is good and should be checked out. If that does not solve the problem, before looking for a replacement transmission check and make sure the clutch is fully disengaging. If the clutch is mal adjusted that can also cause a problem with shifting gears. If the gears are stuck and wont shift at all the problem is most likely with the selector rods and/or forks. In that case you'll need major transmission work carried out. Regards John
Nov 19, 2011 | 1987 Chevrolet Spectrum
How to install a transmission shift cable in a 2000 Cavalier
    • 1 Take the rubber boot off the gear shift inside the vehicle and lift it up, exposing the area where the gear shift and the transmission connect.
    • 2 Look for the shift cable and the shifting arm. A single bolt and nut connect the shift cable and shift arm.
    • 3 Twist the nut connecting the gear shift and the transmission. Use a socket wrench and remove the gear shift. Use an open-end wrench to loosen the nut holding the shift cable and the shift arm together.
    • 4 Slide off the sleeve on the shift cable and loosen the shift cable at the other end with an open-end wrench. Both ends of the shifting cable attach to the shifting arm in different locations.
    • 5 Hitch the new shift cable to the 2 anchor points on the shift arm using the same bolts and nuts. Reconnect the gear shift to the transmission and push the rubber boot back into place around the gear shift inside the car.
    • 6 Test the functionality of the shifting cable by moving the gear shift in and out of gear.
Sep 23, 2011 | Chevrolet Cavalier Cars & Trucks
My car is stuck in second gear, the stick shift is just flopping back and forth. I can not change gears so I am driving with my hazards on and 20mph in second gear. Any thoughts
Is it a stick shift or auto tranny?
If stick shift then the shift fork may be bent thus why it's stuck or
A tranny mount is bad causing the tranny to lean on the shifter mechanism
Or you need a clutch adjustment.
Mar 31, 2010 | 1999 Hyundai Accent
How do I repair the gear shift?
Locate where the shift cable linkage mount to trans, check for good tight attachment to ball socket, then have some one move shift lever through gears watch to see if cable moves shift arm BOTH directions if not replace cable
Dec 24, 2009 | 1991 Volkswagen Jetta
How do you fix a shift cable
To replace the shifting cable for the gear selection, you have to remove first the console box where the gear shift lever is and once you have access to the cable look for a lock that connects the cable to the shifting lever and remove it. do the same on the transmission side of the cable, then when the cable is free from the linkages attached to it pull it out with care. If it is stuck on the brackets loosen and give a slight **** on the cable.
Oct 27, 2009 | 1989 Toyota Camry
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
