Question about Nintendo Game Boy Micro Console
Blue lights come on then right off when plugging in
The blue lights come on right when I plug the charger in, but then go right off and it doesn't seem to charge at all even over night.
5 Suggested Answers
SOURCE: Ds lite ac wall charger
When you first get the DS it will have a bit if charge on it but only a few hours worth. When the DS charges it usally comes up with a orange/red ish light then that goes out about a few hours later when its charged. ad if you want to chek if it is charging correcly turn the DS on whilst it is charging and the little battery simble in the top right corner should show the battery carging.
Posted on Nov 30, 2007
SOURCE: Nintendo DS Lite - does not charge
i would suggest trying to find what the issue is, if you know anyone who has a different charger, try it on your daughter's ds. if it still doesn't work, it's a DS problem...if it's under warranty, go to whatever store you bought it at and have them fix or replace it. If you try the different charger and it DOES work, then the only problem is the charger...so then all you have to do is go buy a new charger...hope this helps.
Posted on Feb 05, 2009
  • 41 Answers
SOURCE: I plug in my ds light to charge and the orange
If your DS is 2.5 to 3 years old, the battery may be bad. Lithium Ion batteries expire 3 years after their date of factory production, so they need to be replaced occasionally.
Also, if there is a kink or break in the electrical cord, it could cause problems. The only real solution, aside from tearing the cord apart and resoldering or taping the severed ends, is to purchase a new charging cord.
If the battery is already 100% charged, it may not display a charging light.
Posted on Jun 23, 2009
amihasib11
  • 99 Answers
SOURCE: www.nintendo.com
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
a-66
Posted on Jul 23, 2009
Will not turn on unless plugged up to charger
Your built-in rechargeable batteries are perhaps defective and do not hold charge.
Hope yours is not a clone.
Mar 28, 2016 | LG Electronics HBS 800 Bluetooth Headset
Peg perego john deere tractor charger indicator light does not light up and tractor does not take a charge - brand new
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show
any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Sep 02, 2012 | Peg Perego John Deere Gator HPX Ride on...
My blue battery pack plugged into the wall is blinking really fast why is this
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Aug 21, 2012 | Peg Perego John Deere Gator HPX Ride on...
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
My Acer Aspire One D255 will not turn on. Light shows blue then immediately goes off. Won't boot on or anything.
Make sure that you have a charge. Try plugging it in and turning it on. If it still doesn't work then you might have a low battery, bad charger, or there could be a problem with the power supply. A bad charger and or a bad power supply would require replacements. You can probably find the charger at best buy or newegg.com. The power supply could probably be found at newegg.com. You might try taking it to a local electronics store and see if they have a different charger they can test it with, that way you would know for sure it isn't the charger.
May 03, 2011 | Acer Aspire One Netbook
Just got a used unit and the battery does not seem to charge. When plug charger in light on charger is green. When I attach the battery the light goes off, and charger makes a humming noise. Is this...
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in, you can order a new one here www.powerwheelsoutlet.com
Aug 26, 2010 | Peg Perego John Deere Gator HPX Ride on...
Plug battery into charger light goes out
Apr 19, 2010 | Peg Perego John Deere Gator HPX Ride on...
My computer was working fine, but I lost my charger. I bought a universal charger and used it for some time. One day I plugged the computer in and the light on universal charger lit up until I plugged it...
I think that your battery is soooo flat it may be no good, take battery out, THEN connect the Correct adapter, and see if that works, if it does, then ya do need a new Batt, or perhaps a good long10-12 hour charge first, with NO use at all during that period.
Jan 26, 2010 | Toshiba Satellite M45X-S331 Notebook
Battery not charging
Nov 12, 2009 | Peg Perego John Deere Gator HPX Ride on...
Nintendo Game Boy Micro Console Logo
43 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
