Question about Whirlpool GEW9250 Electric Dryer
Won't turn on
My whirlpool dryer will not start. I loaded it, shut the door, turned the power on and hit the start button. It clicked and the sensing light is on but the drum does not turn and no heat. Time does count down and all the lights are on but no action. There is no error code either. I can not find anything in our manual troubleshooting section so I have no idea of what this can be. Please can someone help me?
  • 822 Answers
Next to the motor could be a silver capacitor..................may be duff........with the lid off............ powered on..........push the top of the drum...........if it starts going........its the capacitor................be careful..........
cheers
Posted on Jul 29, 2017
SOURCE: Whirlpool duet dryer will no start...the "sensing" light comes on when you hit start; it makes the click noise in the door when you hit start, it counts down, but it does not tumble or anything
you have a blown thermal fuse. you can get one where they have parts it is about 5 dollars.
Posted on Oct 02, 2008
lenwest
  • 150 Answers
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Posted on Jan 30, 2009
  • 289 Answers
SOURCE: Whirlpool gas dryer heats sometimes. sometimes it
sounds like you have a connector that is loose.unplug dryer and check all wire connectors.
Posted on Jan 24, 2010
  • 523 Answers
SOURCE: My dryer timer counts down to 7 minutes and then continues drying
replace the sensa board and make sure the wires on the sensors are ok
Posted on Jun 08, 2010
  • 59 Answers
SOURCE: My Whirlpool Dryer GEW9868KQS has power, but
It's probably either the start switch or door switch. Try bypassing the switch and see if it starts. If it does,you can either replace the switch or try taking it apart and fixing the switch yourself. (I had a switch that simply required a copper contact to be readjusted and its worked perfectly for several years)
Posted on Oct 18, 2011
Dryer will come on but wont start. Sensing light is on
-There are couple things that cause a dryer no to work:
-Thermal fuse, heater element, door switch, start switch.
Good luck
Mai
Nov 10, 2013 | Whirlpool Cabrio WED6400SW Electric Dryer
Whirlpool LER5636PQ1 DRYER starts when I hold the button then shuts off
Your motor has gone bad. Think of the motor as a starter in a car. When you turn the key (press the start button) power is applied to the starter, to be specific, the stator also called the start winding, same as the dryer. Then the rotor takes over and the stator drops off. With your machine the rotor isn't engaging and the stator is taking the load and shutting down.
May 27, 2012 | Whirlpool Dryers
My whirlpool duet dryer will not start. Power
You have to slam the dryer door shut. Sounds silly... but it worked. Guy said it has to do with it being stacked??
Jan 11, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer wont turn on
Ours was doing the same thing you would hear a click and nothing but the sensing light. I found the thermal fuse to be blown Part #3392519. Easy to get to through the front cover under the load door. I went ahead and vacuumed and cleaned out the inside and vent tube.
Jan 21, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool dryer,duet
check the door switch for operation, if the machinr thinks the door not closed == no operation
Jan 11, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
32 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
