Question about Chef's Choice 677 Cordless Electric Kettle
Switch light is not working an it is not heating
Does the total power dissipated on the circuit increase, decrease, or temains the same when the switch is close.
In any circuit, when the switch completes the circuit power will be dissipated in the form of work or heat. Work is the energy used to perform a function, such as turning a motor. Heat is energy lost due to circuit resistance, and the power used to create it.
Think of an incandescent light bulb. When the switch is turned on, the bulb uses energy to create light by passing current through a high resistance wire, heating it up. Here some of the energy produced is lost as heat from the light bulb itself.
Mar 31, 2015 | Cars & Trucks
If light stays on will refridg over heat?
The answer to your question is no,your refridgerator will not over heat. If you don't want to replace door switch you should be able to remove bulbs to shut off lights. I would try working door switch several times to see if it's just not closing all the way. Hope this helps. Thanks
Nov 15, 2010 | Maytag Refrigerator Light Switch -...
Heat light switch comes on..but the heated seat is
MORE THAN LIKELY THE HEATING ELEMENT HAS MALFUNTIONED. ITS A PRETTY COMMON PROBLEM IN HEATED SEATS
Nov 29, 2009 | 2003 Ford Expedition
Passenger heated/cool seats not working
The seat switch or the heated seat relay is bad.Always check your fuses first.
Aug 01, 2009 | 2003 Ford Expedition
Drivers heated seat not working
check the fuse for the dash for the seats.
Jul 21, 2009 | 1998 Jeep Grand Cherokee
Combo lite/vent fan/nite light affected by heat?
There's probably a thermal switch in the fixture which turns the fan on when the lights are on for a period of time and heat accumulates in the fixture. It sound like the heat from the attic is setting off the thermal switch. When the attic heat drops, the fixture works correctly.
This is a catch 22 situation, because if the upper housing in the attic is insulated from the attic heat, the insulation will prevent heat dissipation from the heat generated by the fixture's light bulbs. So, for safety reasons, the upper housing should not be insulated.
I'll need to work on this to come up with a fix.
Jul 19, 2009 | Broan-NuTone N-8663RP Combination Light...
The window on driver side switch doesn't work all the time it gets stuck down. Heated seat comes on all the time sometimes 8 or 10 times in a 5 minute period.
for the power window, check the fuse and relay for same, check the switch by turning on the doom light an then depress the switch, if the light dims then same is working, check the motor by add 12v directly to same. for the heated seats check the switch, its malfuctioning
Jul 18, 2009 | 2004 Chevrolet Suburban
Heated leather seats will not heat up. Switch lights up and all fuses are okay. Is there a hiddedn relay I am not finding? Is there a quick way to determine if the problem is in the heating element under...
are you saying neither the heated seat cushion nor heated seated back on either seat works? But the light or lights does work?
Please rate as solved if this helps you. It took some time to dig all this stuff up. Please report progress.
Here's some info to start you off:
  • The heated seat is inoperative — seat does not heat but the heated seat switch illuminates when pressed
  • Circuitry.
  • Heated seat module.
  • Seat heater and temperature sensor.
  • Seat back heater.
  • Heated seat switch.
May 28, 2009 | 1999 Ford Expedition
Chef's Choice 677 Cordless Electric Kettle Logo
52 people viewed this question
Top Chef's Choice Kitchen Appliances - Others Experts
Tom Chichester
AJMAL KHAN
Christopher Ginn
Christopher Ginn
Are you a Chef's Choice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
