Question about Epson Stylus RX560 All-In-One InkJet Photo Printer
Epson stylus photo rx560 colours not printing properly
Correct ink cartriges but yellow and orange are coming out pink and overall colours are fainter
gwbm
  • 353 Answers
SOURCE: ink cartriges not being recognized by printer
It is not uncommon for an Epson printer to fail to recognise Epson cartridges. It is either due to failing to go through the proper cartridge replacement cycle properly, or more seriously, due to a communication problem between the cartridge and the main board. To fix the first, simply go through the cartridge replacement cycle again (see your manual how to do this before the cartridges are empty). Simply take your new cartridges out when told to, and put them back in again when told to insert the "new" cartridges. If it's the second problem you need specialist help, or simply sell your printer on e-bay for what you can get.
Posted on Jan 31, 2009
gwbm
  • 353 Answers
SOURCE: epson stylus photo 830 my printer is only printing red wwith the word new zealand at the top
Are you confident the new cartridges are full and in-date? Can you confirm that the old cartridges were not removed until immediately before the new cartridge was installed. Did you remove the yellow tape from the new cartridges before you installed them? Were the cartridges changed properly such that an ink charging cycle occurred. Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of ink? Yes, but not perfect cyan-magenta-yellow and black? If so do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're sure you have good ink cartridges properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head
parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean/nozzle check again. If still nothing, post a new comment detailing what you have done and the results.
Posted on Feb 28, 2009
aicaxz
  • 511 Answers
SOURCE: No blue ink
It's seem the cyan head is clog, try the head cleaning use software or manually using head cleaner.
Posted on May 29, 2009
aicaxz
  • 511 Answers
SOURCE: ink isn't low but printing wrong colours, too much pink
is the colour you print is pure yellow (100% or mixed like deep yellow, mixed with little magenta). Is the yeloow nozzle is perfect.
Nozzle check in not always guarantee te print out is good. Cause, when the flow of ink is not good, after the ink spray form the head, the space inside head not fill by ink.
Posted on May 30, 2009
SOURCE: won't print with one empty colour cartridge
That's just ****!!!
Posted on Jun 12, 2009
My printer will not print some colour photos the correct colour in the photogragh. ie 2 examples of this are red comes out yellow & blue comes out orange.
Probably a blocked printhead.
Make a simple graphic using something like PAINT.
Small filled colour squares - one for each colour of cartridge your printer has.
You'll soon see which part of the printhead is clogged.
Make a simple
Sometimes they respond to cleaning, sometimes not.
Sep 22, 2013 | Epson Stylus NX400 InkJet Printer
My epson cx8300 prints a pink instead of a yellow color and a green instead opf a violet one. how do i adjust this?
I think your printer head is block. If yes
#clean printer head by using hot water or alcohol.
and another regon is your printer ink cartrige / refill ink may be alternet. if yeas
#set the cartrige or ink properly.
Thank's
Feb 09, 2011 | Epson Stylus CX8300 Printer
Changed from cartridges to cont. ink system. Now
Hi Dave,
Chances are the problem is that you haven't removed the travel plugs that allow air into the reservoir part of your CIS. This is vital because the air needs to replace ink used up in printing and if it can't do this the air creates something of a vacuum that holds back the ink.
Also worth checking that you haven't got any crimped (folded) tubing or clamps that are still engaged that shouldn't be.
Hope that helps..
Mar 26, 2010 | Epson Stylus Photo 2100 InkJet Printer
I bought ink cartriges from staples, put them in but it says , cannot recognise them?
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. All Generic Cartridges, will print lines thru the words, and also do a mix match with the colors. That's what the Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for the PRINTERS.
Since you do not mention what type of ink cartridges you purchases, this is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Dec 31, 2009 | Epson Stylus RX560 All-In-One InkJet Photo...
Problem with colour printing. Orange and green
Wow, that's a really old EPSON printer. The life expectancy of a EPSON printer is just three years, after that, the printer wouldn't work because of the clogged permanent printing head. The authorized service center is unable to repair it because the spares are no longer supplied.
Throw it to a recycling center.
Nov 03, 2009 | Epson Stylus Color 740 InkJet Printer
Epson rx560 printer no yellow
I thru out an epson ink jet and never bought one again. I did not use it that much and the ink dried in the head and it would not clear out.
I toke it apart and soaked it is almost all the solvents from dish detergent lye for denatured alcohol to napa tested it each time and nota so save the frustration buy a new head or a printer instead. where anytime you place new ink the heads are changed too.
Jul 24, 2009 | Epson Stylus RX560 All-In-One InkJet Photo...
Serious Color Printer Issues
This is to do with the way in which the cyan, magenta, yellow and black ink is mixed to produce all the colours e.g. to print "red" requires both magenta and yellow ink. Thus, if the magenta ink is not flowing for some reason, for example, the "red" will print out as yellow. So, make sure all your cartridges and nozzles are working properly.
If you need further help with this, please post a new comment to this effect.
Oct 18, 2008 | Epson Stylus C62 InkJet Printer
Epson RX560 problems photo printing
RX 560 a printer error has occured see documentation
Sep 03, 2008 | Epson Printer
Only One Ink Cartridge out of Ink But can't print
The machine needs all six cartridges. No way around it. This you could try go online download the Epson utility from www.ssclg.com Installit. learn to use it- click on the icon to set up the printer then right click the task bar icon and look at all the options With all six cart in place use rest set all colours Then try.
Sep 03, 2007 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus RX560 All-In-One InkJet Photo Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
