Back to:
Tags:
Nikon D40x Digital Camera
Nikon d40 shutter not open (by 2 users)
posted by sgs18_eee on Oct 26, 2007
nikon d-40 shutter dosenot open give me solution
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by victory792, posted on Jul 15, 2008
I've had the camera for six months with no problem. Last night, it wouldn't take a picture. When I pressed the button, I could hear a small whirring sound, almost like it didn't have enough power to be operating, yet the battery was fully charged.
Best Solution
posted on Nov 09, 2007
Thanks for Trying (70)
Daveemtb
Rank:Wiz Wiz
Rating: 85%, 92 votes
What are the exact symptoms? What have you tried already? It's impossible to tell from your description whether the shutter is the problem. If it is the case, then you'll need to get it waranteed.
I assume the lens cap is off, you have the lens attached correctly, the AF is working ok (by default the shutter won't fire if correct focus hasn't been obtained.) and you have a memory card inserted in the camera?
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on nikon d40 shutter not open:
I don't want to Accept this solution
Solution #2
posted on Jan 07, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I had the same problem and sent it back to Adorama where it was purchased. They delt with Nikon who promply replaced the camera.
Thank You!
Can you Help with these Digital Cameras problems?
Even though I hit the flash button on the side of the...
Where can I get the cheapest replacement for Nikon D40
my D40x Digital camera's power supply board was damage or...
NEver had the problem removed card form comoputer and it...
When I turn my d40x power switch off and I press the...
Loading problems.
Repair Service
Find Digital Camera Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
