Question about Morphy Richards Kitchen Appliances - Others
Accents pyramid kettle won't boil
Accent kettle won't boil
jerryg50
  • 1667 Answers
SOURCE: kettle lights but doesn't boil
Most likely the thermo fuse is blown.
You have to take the kettle apart and see the spec for the thermo fuse. You can get these at most any electronics parts supplier for appliances.
To change the thermo fuse you will need the proper crimp type connectors and the crimp tool. This is not able to be soldered. It runs too hot, and soldering in a circuit close to a heating element is not able to be used.
Before changing the thermo fuse, you can test it with an ohm meter. It should typicaly read about 0.1 to 0.2 ohms. The heating element resistance should typicaly read about 8 to 12 ohms.
If the heating element reads below 6 to 7 ohms on a well calibrated ohm meter, or above 15 ohms, it is defective.
If the thermo fuse is blown, the kettle may have been left running when boiled out and over heated, or there is a short in the heating element.
If you feel that you are not comfortable to do this type of repair, it would be best to give the kettle out to an appliance service centre to have it serviced.
When you change the thermo fuse, and if it blows again the heating element is probably damaged. It must be replaced if possible, or if worth the cost.
On the other hand, if the kettle is more than a few years old and you don't want to go to all this trouble, you may want to consider to simply get a new one.
Jerry G.
Posted on Apr 29, 2008
  • 1416 Answers
SOURCE: Why does the water boiled in this kettle smell and
hello,
the chemical taste of smell from your kettle means that the element in the kettle which provide heat to boiled the water has gone bad due to over heating
this occur when there is shortage of water level in the kettle when the power supply is on
to fix up this problem of smell and chemical taste in your boiled water you will have to make a change of the element (heater)because it has gone bad you can get a replacement of it in the store .
thank you and thanks for using fixya.
Posted on Jun 01, 2010
Testimonial: "Glad to hear it's not my imagination. On complaining to the retailer they suggested that I have a very delicate palate, or do I have fillings in my teeth!!! I do, but my 85 year old mother sure doesn't. Thanks again."
homemender
  • 158 Answers
SOURCE: When filled with water & put on to boil it
I think you would only solve this problem by cleaning the thermostat contacts, or replacing the thermostat which wouldn't be worthwhile as it's likely to be cheaper to buy a new kettle.
Besides this , just getting into the kettle needs special 3 tongue screwdriver and then a certain technique to open it up without damaging the plastic parts. Im'e afraid its a throw-away world now and its not good .
Posted on Dec 23, 2010
SOURCE: water kettle does not boil water
I had the exact same problem. The kettle would warm water but not boil. I bet you have hard water - try putting 1/2 vinegar and 1/2 water mix and turning it on. I did this, fixed the problem!
Posted on Dec 25, 2010
SOURCE: Hi there Hiw can I turn off the whistle on the
You can turn off the electronic whistle on the morphy richards kettle by moving the switch (marked with a musical note) which is located underneath the electric base unit (not on the kettle itself).
Posted on Jun 30, 2011
My 1998 hyundai elantra will not go in reverse...any ideas?
Hyundai Elantra transmission won t go into reverse m ...
www.fixya.com > ... > Cars & Trucks > Hyundai
Hyundai Elantra cars & trucks transmission won t go into reverse m ... Question about 1998 Elantra. 1 Answer · Reverse gear almost dead in 1998 Lantra auto.
99 accent wont go into reverse - Hyundai Forums : Hyundai Forum
www.hyundai-forums.com/...accent/157948-99-accent-wont-go-into-rev...
Mar 28, 2013 - 3 posts - ‎3 authors
Here is my situation and am hoping I might get somebody who can actually help me with this. I have a 99 hyundai accent automatic with ... 2001 Accent No Reverse
Apr 10, 2011
1998 Hyundai Accent Automatic Trans Problem ...
Dec 6, 2005
More results from www.hyundai-forums.com
Why is it having trouble moving in reverse?
Jan 05, 2016 | Hyundai Cars & Trucks
Filter replacement
Remove limescale with vinegar. A thorough job will clean filter too!
Feb 17, 2014 | Morphy Richards Accents 43836 Jug Kettle,...
How to repair slight scratch on red accents kettle
goto a store like canadian tire or a auto parts place and get a color match pen in your color or a touch up pen for cars for scratchs
Jan 22, 2014 | Morphy Richards 43691 Cordless Electric...
1999 Hyundai Accent hatchback won't open
like at all? i have an issue where mine wont close want half of it? lol. i have to tighten the screws on mine in order to make it close. maybe do the opposite?
Dec 05, 2012 | 1999 Hyundai Accent
1999 Hyundia accent door handles won't work
Go to ebay I bought two new outer handles and two inners for my '97 accent. They are five bucks a piece you can't beat it and free shipping. Take the inner panel apart if you're going to change them yourself. You have the mirror guard that pops right off with a flathead screwdriver, then unscrew every philips-head bolt on the panel there should be roughly four screws. Then once you remove the panel, two 10 mm bolts for the handle which are inside the door are what hold the handle on. Good Luck! http://www.ebay.com/sch/Car-Truck-Parts-/6030/i.html?_nkw=1997+Hyundai+Accent+door+handle
Aug 04, 2012 | 1999 Hyundai Accent
2005 Hyundai accent won't start. it turns over but is not starting.
You'll have to figure out if it is a fuel or ignition problem.
Check and see if you are getting spark to the plugs first.
Also re-check the computer for codes and see how many are back.
Trouble codes are suggestions, not solid instructions.
Jun 28, 2012 | 2005 Hyundai Accent
Hi there Hiw can I turn off the whistle on the Morphy Richards Accent kettle please?
Mar 03, 2011 | Morphy Richards 43691 Cordless Electric...
2001 Hyundai Accent. Heating and stalls
If the water tends to keep going down then there has to be a leak somewhere. Try also looking at the hose coming from the overflow tank and see if the hose might be kinked. You might also be blowing antifreeze out the tailpipe. Take a look and if there is bluish white smoke then you have confirmed that theory,
Jun 10, 2009 | 2000 Hyundai Accent
Kitchen Appliances - Others Logo
Top Morphy Richards Kitchen Appliances - Others Experts
Mike
Ruth summersides
Are you a Morphy Richards Kitchen Appliances - Other Expert? Answer questions, earn points and help others
