Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
No water, check supply
The water supply previously cut out whilst the machine was mid cycle. The water has since returned but the error message "no water, check supply" keeps flashing towards the end of every cycle. The water does not drain and the cycle never comes to an end. The detergent is also not being properly drained from the drawer.
  • 1462 Answers
SOURCE: Machine stuck mid cycle
filter blocked or brawire or similiar in drain pump take off cover at bottom rear. take of hose going to bottom of tub. filter is in that hose you will have water everywhere. one way round that is to lay machine on side - left side down viewed from rear
Posted on Mar 20, 2007
jason0110
  • 66 Answers
SOURCE: error code h20
hi sounds like a faulty fill valve easy fix
Posted on Sep 21, 2008
barkencoa
  • 3463 Answers
SOURCE: water constantly in the drum of the washer dryer
It is possible that the inlet valve is sticking,open
Pull the dispenser drawer right out, and see if you can see water trickling in after it has finished.
If you can, then the valve is not shutting off properly, and you will have to replace it.
The other thing you can do is to remove the top cover, and remove one by one the black hoses that go from the valve to the dispenser, and see if you can see water coming through, if you can then replace valve.
The other possibility is that the valve is getting a permanent feed from the board/timer, to check this you would need a meter to test for voltage.
Plz rate my solution.
Thanks.
Posted on Jan 16, 2009
SOURCE: the water wont drain or spin wf210 hotpoint
Hi I think your problem is that the filter is blocked, filter is located between drum and pump at the rear, clean that out and that should solve the problem.
Posted on Mar 28, 2009
barkencoa
  • 3463 Answers
SOURCE: Hotpoint WMF720p - getting message F05 can you
You need to check and clean the pump filter.
If there is no filter located at the front of washer, (check handbook),
Then remove the rear lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Fit back and test
Please rate my solution.
Thankyou.t.
Posted on Jan 31, 2010
LG washer WM2501HWA quit mid cycle and had an OE error message. The drain filter was checked and was clear. I drained out all the water through the drain hose. For a time, the drum would not spin. When...
i believe if the water outlet is still good,,,,,u will have to loose out the pump from its cup , mayce something hooked its propeller inside the i cup or replace the water pump
Jan 25, 2015 | LG Washing Machines
No water check supply
keep on pressing the start button for 30 second it should reset
Feb 08, 2014 | Hotpoint Ultima WD72 Front Load...
H6 error code on a NEC NFL-1065 washing machine
see this causes, and fix it. God bless you
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
f the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components
f the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Sep 26, 2012 | Washing Machines
Washer stop in middle of rinse cycle
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Asko washer 20004 stopped mid cycle, water is
Do not play with water and 240volts or 120 volts....it is a LETHAL cocktail.
Get a techo to save you the headache and possibly YOUR LIFE!
Oct 19, 2009 | Washing Machines
My whirlpool duet front load washing machine stops in mid cycle
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine problem
"dE"
- Lid open error Lid is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check water inlet valve
· Check pressure sensor switch
Apr 30, 2009 | Washing Machines
LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Apr 27, 2009 | LG WM2487H Front Load Washer
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
