Question about Panasonic TC-P50S1 50 in. Plasma LCD HDTV
PANASONIC TC-P50S1 NOT POWER ON, 10 BLINKS
DOES NOT POWER ON, JUST 10 BLINKS
  • 35 Answers
You need to either replace your PSB-power supply board with a refurbed one or replace the Blown capacitors on the PSB. Solder kit w/ flux from harbor freight or radio shack and about a dozen thru-hole caps about 2v above the current load rating on the blown caps. You can also just buy one from shopjimmy ebay or partsstore. You have to remove the back panel and remove the PSB. The board will be printed Power Supply and the REV number (part number) will be on it as well use that to replace. Disconnect the wire harness/ribbon cables and a few screws to pop the board out. take pics or number the wires/cables so you know where to plug them back in when either the repair or replacement is done.
Posted on May 13, 2014
  • 20 Answers
SOURCE: my panasonic th-50pz800u won't power
A red light blinking 10 times means that a video board has gone bad. Contact Panasonic to see if they will help you out.
Posted on Jan 04, 2009
  • 8457 Answers
SOURCE: I have a panasonic viera tc-p50s1 and I can't get
The power supply board have problems,it not giving the right voltage to the tv anymore.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbush power supply board for the replacement.
Posted on Oct 11, 2010
Testimonial: "Great Help with trying to get my tv back up and running."
  • 12 Answers
SOURCE: Panasonic TC-P54G25 plasma hdtv won't
Perhaps an easy fix. Remove the back of the flat screen. There will be a main circuit board visible. There will be several capacitors, cylinders with a cross hatch on the silver top. Do any of them look like they have a dimple created by expansion of the internal capacitor material over heating? If you see an expanded top...that's probably your problem. Get your solder gun out and replace that capacitor. You can order a new one off of Amazon. If yours is a 10 volt capacitor, consider replacing it with a 16 volt unit. Generally the electronics companies under design the size of these units. When you replace the capacitor take note of the silver band on the unit and where its placed in the two socket holes....there is a positive and negative hole placement.
Posted on Jan 03, 2011
  • 4 Answers
SOURCE: WILL THE Panasonic DY-WL10 Wireless LAN Adapter
maybe xbox
Posted on Mar 08, 2011
sodeep
  • 3267 Answers
SOURCE: I have a Panasonic Model TC-P50S1 plasma TV and
Panasonic utilizes the blinking light as a form of self-diagnostics, similar to the "check engine" light in your car. If you've ever experienced that, you know that a check engine light could indicate anything from a loose gas cap to a major failure.
Panasonic uses the number of times the light blinks, to aid the technician in trouble-shooting the problem. The blinking light indicates an area of concern and helps the technician to isolate the problem and order the correct parts. This in turn speeds up the repair process, keeps parts cost down, and helps both you and the servicer by allowing the technician to complete a repair in one trip in most cases.
So contact an authorized service center.
Posted on May 28, 2011
I have A Panasonic TC-P50S1 TV picture blinks then goes out red power button blinks I can hold power button down for second and TV comes back on but goes out again
The Power Supply Board is bad and needs to be replaced. Another symptom maybe a clicking sound when the unit is trying to turn on.
Jul 05, 2015 | Panasonic Televison & Video
What does it mean if i get 6 blinks on my tc-p50s1
i guess it would be the PSU board,remove the back lid an check for any blown capacitor and replace it yourself - having an ESR meter will help to detect the other bad ones that will not last long
Jun 05, 2014 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
Panasonic tc-p50s1
Could be a failing power supply.
Mar 05, 2014 | Televison & Video
TC-P50S1 will not power on after power surge
try unplugging from power for at least 30 seconds. if that doesn't work, it may be a fuse. see the picture for the fuse location.2_25_2013_1_41_21_am.jpg
Feb 24, 2013 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
Red power light turns on then repeatedly blinks 7 times
Ask Panasonic (lt's posted here as one) or GOOGLE THE MODEL NUMBER WITH "BLINK CODES" OR ERROR CODES.
Mar 25, 2012 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
I have a two yr old panisonic TC-P50S1 that wont power up . You hear it click on then it shuts off ?
Hi no power and a clicking sound usually means that your power supply is bad. You will need to replace it.
You can get parts at www.interliquidparts.com
Nov 29, 2011 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
I have a Panasonic Model TC-P50S1 plasma TV and the red indicator light continuously blinks and the TV never does come on. Can this be fixed?
May 28, 2011 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
WHILE WATCHING MY TV TONIGHT I HEARD A LOUD POP AND NOW NO PICTURE JUST BLINKING RED LIGHT
10 blinks for this tv is not always an A Board issue. It can be a problem with the power board as well. A technician should look at the set to dertermine where the problem lies otherwise it is just a guessing game of inni minni miny moe.
Apr 03, 2011 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
My TV just turned off and the power light flashes 8 times. what is the flash code for 8 times on a panasonic TC-50PS14
thought I would post this here for everyone.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
May 14, 2010 | Panasonic Televison & Video
Panasonic TC-P50S1 50 in. Plasma LCD HDTV Logo
223 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
