Question about Eagle Fishmark 320 Portable Fishfinder
Electronic components - Eagle Fishmark 320 Portable Fishfinder
How can I replace the accelerator pedal assembly?
It's easy ! Disconnect the electrical connector , un bolt it .
Removal Procedure
Notice: Handle the electronic throttle control components carefully. Use cleanliness in order to prevent damage. Do not drop the electronic throttle control components. Do not roughly handle the electronic throttle control components. Do not immerse the electronic throttle control components in cleaning solvents of any type.
Remove the connector position assurance (CPA) retainer. Disconnect the accelerator pedal position (APP) sensor electrical connector. Reposition the carpet to access the lower nut.
Remove the accelerator pedal nuts. Remove the accelerator pedal assembly.
Feb 09, 2016 | 2003 Chevrolet Suburban
What is power supply
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary
Sep 08, 2014 | Televison & Video
Toshiba 42HM66 projector seems off.
it seems like hardware issue which may be due to faulty electronic components inside. So what i can tell you is that you take it to the nearest servicing center so that they can repair it. Repairing this kind of issue may involved opening and checking faulty electronic components which include risk of electronic shock if not open by knowledgeable person. thank you
Mar 21, 2013 | Televison & Video
What is different between electronic circuit & PCB layout.
The electronic circuit is the map of the components and and the flow of the current, (schematic) PCB (printed circuit board) is the layout of the components (where they go and symbols of what they are.
Hope this helps
Jan 12, 2011 | Lands Phones
What would cause my jeep when you turn the corner to cut out? It has been doing it for a couple of days....we were stopped at a stop sign and it just cut out....yesterday we changed the fuel pump and it...
I cannot think of anything solid state that would malfunction when just turning a corner. However, the automatic idle speed motor may be malfunctioning. But, for your interest, here are the various engine controls that exist on the Jeep Grand Cherokee: COMPONENT LOCATIONS Fig. 1: Electronic engine control component locations - 2.5L engine shown 91074g07.gif
Fig. 2: Overhead view of the (A) automatic idle speed motor, (B) MAP sensor, (C) crankshaft position sensor wiring harness, (D) air temperature sensor, and (E) throttle position sensor - 1992 Cherokee with the 4.0L engine shown 91074p15.jpg
Fig. 3: Electronic engine control component locations - 4.0L engine shown 91074g08.gif
Fig. 4: Electronic engine control component locations - 5.2L and 5.9L engines (Part 1 of 2) 91074g05.gif
Fig. 5: Electronic engine control component locations - 5.2L and 5.9L engines (Part 2 of 2) 91074g06.gif
Oct 15, 2010 | 1997 Jeep Grand Cherokee
Where is the knock sensor located on my 92 Jeep Cherokee 4.0L straight 6 4WD?
I don't see the knock sensor on the 4.0L engine. --- COMPONENT LOCATIONS Fig. 1: Electronic engine control component locations - 2.5L engine shown 91074g07.gif
Sep 30, 2010 | 1992 Jeep Cherokee Briarwood
Pop spilled into car's dvd player about 1.5 months ago which I didn't realize. Now the DVD player won't ''****'' in the DVD. Thoughts? Help? If I can't fix it, who do I contact to fix it? I would think the...
I imagine the liquid made the leads to some electronic components rusty and deteriorated., since it took that long to stop working. Electronic components have value, and replacing them requires exact same value. I imagine it has what you call surface mount technology in which the components are so small, that it is very difficult to replace. Sadly there is no easy fix when dealing with electronic circuits. Me trying to show you how to fix it would be futile, since electronic circuits and theories take a long time to learn, and almost like a college course.
Nov 25, 2009 | Car Audio & Video
Crankshaft position sensor
where it the crank potision sensor on a 92 mitsubishi diamante
Sep 15, 2009 | 1998 Mitsubishi Diamante
Error code 065 jjj jjjj jjj 065 (frigidair Model feb398ceb)
2 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace F2 Oven too hot Check Bake function F3 Oven temperature sensor open Check oven temperature sensor, 1100 ohms F4 Oven temperature sensor shorted Replace component F5, 6, 7 EOC (Electronic Oven Control) failure Replace component F8 Lock switches Check or Replace component Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control) F2 Oven too hot Likely a bad oven temperature sensor (should read 1100 ohms) Possible bad EOC (Electronic Oven Control) F3 Oven temperature sensor open Replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5 or F6 or F7 EOC (Electronic Oven Control) failure Replace EOC(Electronic Oven Control) Version 4 Failure
Code
Condition Check/Repair F1 Circuit board defective Replace control board F2 1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check 8-pin connector. Check and replace oven temperature sensor if necessary F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control F4 Oven temperature sensor is shorted (below 500 ohms) Check resistance of oven temperature sensor, check for shorted wiring between oven temperature sensor and control F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control) F6 Shorted buttons Check push buttons and dome switches on control F8 Logic interrupted (lock motor switch sequence) Check door lock switches and wiring
Nov 18, 2008 | Frigidaire Kitchen Ranges
Eagle Fishmark 320 Portable Fishfinder Logo
Top Eagle Boating Experts
Steve
Steve
ray gallant
Al Toledo
Are you an Eagle Boating Expert? Answer questions, earn points and help others
