Question about ICOM Informatique BP-85S, ICOM,IC-W2A,IC-2SRA,IC-4SRA,IC-2SAT,IC-3SAT,IC-4SAT,IC-24AT,IC-RI,IC-X2A, 12v 1100mAh NiCd ... 2-Way Radio
What is the frequency coverage of ic-7100 - ICOM Informatique BP-85S, ICOM,IC-W2A,IC-2SRA,IC-4SRA,IC-2SAT,IC-3SAT,IC-4SAT,IC-24AT,IC-RI,IC-X2A, 12v 1100mAh NiCd ... 2-Way Radio
    Habit-Forming:
    New Friend:
  • 34 Answers
The frequency coverage of ic-7100 - ICOM IS FROM 1MC TO 450 MC
DAN
http://www.rylwy.com/
Posted on Dec 07, 2016
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 69 Answers
Nokia c2 00 phone say no network coverage problem
Nokia c2 00 phone say no network coverage problemjust make jumpaer v- vat to pf.... power ic or pf is always ok in ths problm
Dec 02, 2012 | Nokia mobile C2-00 Dual SIMbiosis
What is the frame output ic
Hello
Frame output IC means nothing, but the VERTICAL OUTPUT IC. Every TV will have it, which will scan picture vertically at 50 or 60 Hz. [1 HZ means one frame per second. Normally TVs will have 50Hz, 60Hz and 100Hz vertical frequency]. As vertical frequency rat increases, the picture fliker wil decrease. High level high-cost TVs will have 100Hz or even more frequency will be used for vetical scanning.
In the case of computer monitors, the vertical frequency will vary from 60Hz to 120hz. You can see its picture stability, at this high frequency.
The IC [Integrated Circuit Chip], which generates the vertical frequency and outputs it called the vertical output [frame output] IC. OK
Wish you a Proseperous and Happy 2012.
Gopakumar G, Trivandrum City, Kerala State, South India.
Dec 29, 2011 | Televison & Video
I have a uniden bearcat scanner 30 channel i would like to know if it is possable to add any software or chip to make it able to pick up aircraft frequencies ? ...
Sorry, but it's been a long time since scanners could be modified to extend or change their frequency coverage. The AIR band in your BC350C allows you to monitor commercial, private, and some military aircraft. If you want full military air coverage though, I suggest that you look at the reasonably-priced BC370CRS.
Bill B.
Listening in since the 60's
Jan 29, 2011 | Uniden BC350C Base Scanner
Installed this NT9K08AD03 where a NT8B30AD03 was and the new phone does not work. Meridian Compact ICS 2.0
The M2008 set (NT9K08AD03) doesn't work on a CICS system. It works with the Meridian PBX systems. The type of sets that work with a Compact ICS system are M 7100, 7208, 7310, 7324 and T 7100, 7208, 7316, 7316e as well as some of thier cordless sets.
Oct 01, 2010 | NorStar M2008 PBX Phone (nt9k08ad03)
How to add frequencies/channels to ICOM IC-F21 two-way radios?
Sorry, but your radio is limited to 16 channels in the 400-430 and 440-470 MHz ranges. The number of channels cannot be expanded, nor can the frequency coverage.
Bill B
Mar 28, 2010 | ICOM Informatique Icom IC-F21 16ch UHF...
I cannot figure out what setting to put it on to oick up all it capitable of picking up its on 50 mhz now all get is the local area will you help me with this problem as I spent all my money on buying it...
Sorry, but there's no simple answer as channel spacing varies with frequency/band. The majority will be using 5.0, 10.0, 12.5, and 25.0 KHz steps within the USA, but you'll have to experiment with each band. You're skipping over most VHF and UHF signals using the current 50.0 step setting. The R5 is a wide-coverage receiver with lots of features, but the manual leaves a lot to be desired, the receiver is missing features like automatic step selection (found on almost all scanners), and operation can be extremely difficult. Much of your use will involve interpreting the manual and experimentation.
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Dec 29, 2009 | Icom IC-R5 Handheld Scanner
PROGRAM FREQ IN BC142XL
Its so easy to use you really don't need a manual for the Uniden BC
142XL scanner.
Turn it on. Push the MANUAL button to stop it from scanning.
Push number 1, then push MANUAL again. This should leave you on
channel one.
Using the keypad enter the frequency you want to monitor, then push
E. Press REVIEW at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the display, you might be entering an invalid frequency. Refer to the frequency coverage list below.
Push MANUAL to step to channel number two. Enter the frequency. Push E. Push MANUAL to step to channel three. Repeat this process until all ten channels are programmed, or you've run out of frequencies to enter.
Push "SCAN" to start automatically scanning the frequencies. The
radio will stop when it hears someone talking, and resume scanning two
seconds after the conversation has stopped.
Frequency Coverage:
20 to 29.7 MHz (10 Meter "Ham" Band)
29.7 to 50 MHz (VHF Low Band)
50 to 54 MHz (6 Meter Amateur Band)
136 to 144 MHz (Military Land Mobile)
144 to 148 MHz (2 Meter "Ham" Band)
406 to 420 MHz (Federal Government Land Mobile)
420 to 450 MHz (70cm "Ham" Band)
450 to 470 MHz (UHF Standard Band)
470 to 512 MHz (UHF "T" Band)
Nov 07, 2009 | Uniden BC248CLT Base Scanner
Radio Communications Logo
219 people viewed this question
Top ICOM Informatique Radio Communications Experts
eradiostore
eradiostore
BJ Russell
Steve
Are you an ICOM Informatique Radio Communication Expert? Answer questions, earn points and help others
