Question about Panasonic Lands Phones
Kx tc1465lab 900mhz
Battery
Re: Panasonic KX-TC1402 900MHz cordless phone ..... Had "recharge" indicator showing. Replaced battery and seemed to work OK for a couple of months (until the new battery ran down?). Now the...
I had this phone for awhile. finally connected and it worked for awhile. I unplugged to move to a different room now it doesnt work. The in use light does not work.
Apr 09, 2011 | Panasonic Cell Phones
We need to change the time displayed
If this is a TA system, you change the time from the phone connected to Jack 01 (usually ext 101). On the phone, press PROGRAM and dial 0. It will display the current date and time in the following form:
YYMMDDwHH:MMa Where w is day of week (Sunday being 1) and a is AM or PM where AM is 0 and PM is 1.
Key in the new info and press STORE.
If it's connected to a TAW-848 or other Panasonic system, you still change the time from the same extension, but you have to go into system programming. Comment back if that's the case and include your system model number.
Carl
Oct 26, 2009 | Panasonic KX-T7735 Corded Phone
Finding replacement battery kx-a276
Take the battery out and take it to Walmart or Radio Shack. A lot of times you won't find that exact model number but the batteries they sell are exactly the same.
The Number kx-a276 is just the Panasonic model number for a battery many other phones use. On the back of the battery package replacement you should see "kx-a276" listed.
Hope this helps!
Fix it?
Jun 01, 2009 | Panasonic KX-T7885 Cordless Phone
How to adjust ringer volume
Yours is a little different from mine, but maybe this will help some, I hope. On the "talk" side, there is a button (2nd from right on mine) which says "loud" over the button, and "ringer" under the button. Pushing the button once gives you the soft ring. Pushing the button again will give you the loud ring. If you have gone to the loud ring, you will get the loud ring on the first time. Then you can push it again to get you back to the soft ring. I hope this helps.
Jan 23, 2009 | Panasonic 900 MHz Cordless Phone
900MHZ CHARGING LIGHT STAYS RED AND DOES NOT GO OFF
Didyou try taking the battery out of the headphone and replacing it? This may act as a reset and allow charging. I'm assuming that these headphones are not brand new, and that you are lining up the arrow on the one side with the arrow on the charging base. This is the only way the inductive charging can occur. Good luck!
Dec 22, 2008 | Sony Camcorder/Audio/Video 900MHz Wireless...
I have a motherboard that support up to 900MHz, can i use a 1GHz CPU with it?
I would say no, since 1GHz is greater than 900MHz by 100MHz and you state that *********** Board only supports up to 900MHz.
Sep 18, 2008 | Computers & Internet
Instruction manual for Uniden 900MHz Extend-A-Phone
go on your computer to www.uniden.com and click on 'get instruction manual' and then give them the info.
Apr 25, 2008 | Panasonic KX-TGA101S Cordless Handset
Try here: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Expandable-Systems/model.KX-TG6021M
Click where it says download and the manual should download.
Feb 04, 2008 | Panasonic KX-TG6021M Cordless Phone
Lands Phones Logo
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
