Question about Sharper Image Literati Reader 16375680042 Tablet PC
Literati will not connect to mifi
Will not connect to mifi
I cannot connect my mifi verizon hotspot device to my transformer tablet tf300
Delete any other 'mifi verizon' connections from the 'wifi and networks' then restart (switch off for 10 secs by removing power cable) on both mifi and tablet and try agiain.
Jun 01, 2013 | Tablets & eReaders
I cannot get the Literati to install the driver on my computer, nor can I find a driver installation online. Help.
There are no drivers for the Literati. You can try updating the firmware to 1.9 to see if it fixes the problem. To update, connect the Literati to your network via WiFi. The update will be pushed to you.
May 07, 2011 | Sharper Image Literati Reader 16375680042...
Cannot connect to my wireless network
I got my Literati for Christmas and downloaded a book. The other day I went to go and purchase another thru the WiFi on Literati and I can't get connected to ANY Wifi even an unsecured one.
Jan 21, 2011 | Sharper Image Literati Reader 16375680042...
How do you know when your literati is charging
In the upper left hand corner of your Literati there dispalys a battery looking icon. In this icon will display a cable plug once you connect the charging cable.
The hopeless literati guru
Dec 27, 2010 | Sharper Image Literati Reader 16375680042...
Unable to join network
Found this written by someone on another website - worked great for me - not a problem since - have downloaded books via Kobo website straight from the device, everything works perfectly. Thank goodness this person posted.
Go to advanced and reset the system to the mfg settings & it will power down. Turn back on, don't set the date/time & instead reset the system again a second time. At this point it may take awhile to power down and come back on but once you go thru this process, your Literati will update w/ the latest software and work. I followed these instructions and works great now no problems at all.
I can not get my literati to join with my network
It needs the latest firmware 1.9 or 2.0 for the wireless to work correctly. The solution is to get the usb to work first. Plug and unplug the usb, try powering on with usb plugged in until you get the pc to recognize the drive in the literati. Once you get to this point you have it made. Browse the drive and find the "Desktop Installers" folder run the windows install - the pc will then go out to the internet and get the desktop software version that can update the literati. Once the desktop software finishes installing it will tell you that the literati must be updated. Let it do it. Power off literati or reset it. When it comes up again the desktop software will say there is another update. This one is a big one. After it finishes Power off or reset literati again and it will load the newest firmware and the device works much better afterward. Also, you might want to keep it plugged in to power while you do this - Don't want it to lose power during firmware update.
I can log into the internet and cannot reach the store. Under setting I see the Revision is blank.
Ok! This is what I found out personally. The Wi-Fi connection needs to be a non-hot Wi-Fi network. Meaning certain Wi-Fi connections has a security lock preventing any file transfers. I tried several locations to make a connection (Coffee shops, Mc D's, Library, Work, etc.). The Best way to connect your Literati is to find a friend who has a Wi-Fi router and ask him/her of their password temporarily.
Now you need to enable the Wi-Fi under the settings area by hitting the menu button and scroll down to the settings tab. select the Wi-Fi or wireless option. Enable the Wi-Fi and your unit should start scanning the area networks. This is where you'll find your friends link or an open unsecure network. Do not select any links that have a pad lock unless you know there password. Once you join, wait about 1 minute and the unit will prompt you to update the software.
Now! The software version you need to have is version 1.9 or greater. After you upload the software patches which should take two or 3 times (Including restarts & power offs).
After this point you will need to set up an account thru the KOBO website ether using your PC or the Literati under the store tab. Once your setup with an email account it should display itself under the overview area on your literati under settings. From here it all downhill...
The Hopeless Literati Guru
Dec 26, 2010 | Sharper Image Literati Reader 16375680042...
I cannot connect my Literati to WIFI
Ok! This is what I fund out personally. The WiFi connection needs to be a non-hot Wifi network. Meaning certain Wifi connections have a security lock preventing any file transfers. I tried several locations to make a connection (Coffee shops, Mc D's, Library, Work, etc.). The Best wy to connect your Literati is to find a friend who has a WiFi ruouter and ask him/her of there password temporarly.
Now you need to enable the Wifi under the settings area by hitting the menu button ans scroll down to the settings tab. select the Wifi or wireless option. Enable the Wifi and your unit should start scanning the area networks. This is where you'll find your friends link or an open unsecure network. Do not select any links that have a pad lock unless your know there password. Once you join, wait about 1 minute and the unit will prompt you to update the software. From here it all down hill..
Lookbook wireless reader manual
I am having a problem get my lookbook hooked up with my wireless service I have verzion wireless.
Nov 29, 2010 | Sharper Image Literati Reader 16375680042...
Sharper Image Literati Reader 16375680042 Tablet PC Logo
16 people viewed this question
Top Sharper Image Tablets & eReaders Experts
Lawrence Oravetz
Tom Chichester
Are you a Sharper Image Tablet and eReader Expert? Answer questions, earn points and help others
