Question about Maytag MSD2756GES Side by Side Refrigerator
What year was the msd2756ge made - Maytag MSD2756GES Side by Side Refrigerator
My maytag MSD2756GE has just recently stopped cooling. The inside lights and the indicator lights in the water/ice dispensers are on, but the refrigeration has just completely stopped. There is no sound...
check the ptc overload on the compressor it may be bad or the temperature control can be bad also,you can jump the 2 wires to this control and see if the unit starts,then if so replace the control
Mar 22, 2011 | Maytag MSD2756GES Side by Side...
Freezer cold, fridge is not. damper door not opening, maybe? has an electric thermostat. possibly failed? Maytag MSD2756GE. how do i diagnose the t-stat?
Click here => MSD2756GE on page 38 of the service manual is where testing begins. If you need one Click here=> 61005971 or here=> Sea Breeze Tip's and scroll down a little. If you need a little help let me know but already sound like you can hold your own. Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Apr 12, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag MSD2756GE Side by Side Fridge
You have a bad compressor, time for a new refrigerator. Check your warantee for compressor failure. Might be 5 years.
Dec 31, 2008 | Maytag MSD2756G Side by Side Refrigerator
Maytag refrigerator side-by-side model MSD2756GE freezer is working fine, but refrigerator is not cooling. can not hear a fan blowing from freezer to refrigeration side.
remove the baskets and shelves in the freezer and remove the rear panels after shutting the fridge down. If you see heavy frost on the coils then the defrost model needs replaced. If not, check the that the fans runs, and then that the thermostat works and then that the damper that allows the air to the fridge compartment is opening correctly.
Jul 12, 2008 | Refrigerators
Maytag refirigerator not freezing/cooling
Turned out to be a bad circuit board on the back of the unit which caused the refrigerator/freezer to freeze up. Replace it, thawed the refrigerator compartment, and it works fine. Cost me less than $200 including service call.
Jun 22, 2008 | Refrigerators
Maytag MSD2756GES Side by Side Refrigerator Logo
71 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
