Question about Mitsubishi WD-60737 TV
Error code 17 for mitsubishi wd 60737
Help
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: wd-60737 mitsubishi blinking yellow status light ?
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on Oct 26, 2012
WD 60737 error code 12 what do i need to do. We replaced bulb and now it just flashes red
Error code 12 is no problem found. I would make sure I had the right bulb, make sure it is seated properly, and make sure the door to the lamp box is on correctly. If that doesn't work, and you still have the old bulb, put it back in. Even if it doesn't work it will display a bad bulb code and not the current one if your new bulb is incompatible. Sometimes that happens when you get a new bulb with incompatible specs.
Sep 11, 2016 | Mitsubishi WD-60737 60 in. HDTV
Mitsubishi wd-60737 won't turn on just flashes red I get error code 12
Hm Code 12 is "no error". Which is odd since you have an error.
However, since the age of the TV is around 7 years, you may have the problem that the power supply is known for. The capacitors in the power supply fail.
To be safe, check the lamp and make sure its in good order. May want to change it anyway if its more than a year or 2.
Sep 10, 2016 | Mitsubishi WD-60737 TV
Mitsubishi WD-60737 balast replacement
Hi, take a look at this video to see if this helps.
https://www.youtube.com/watch?v=Wuy75C_HRb4
Jul 11, 2016 | Mitsubishi WD-60737 TV
Blinking code 3 2. will not turn on
error code 32 indicates the lamp cover is open, you might also check that lamp cover switch.
Mar 15, 2015 | Mitsubishi WD-60737 TV
Mitsubishi wd-60737 fan problems
i have the same tv i replaced the lamp n now its a oange blinking light on
Feb 27, 2014 | Mitsubishi WD-60737 TV
Wd-60737 mitsubishi blinking yellow status light ?
Oct 25, 2012 | Mitsubishi WD-60737 TV
Mitsubishi DLP - WD-60737 - 1 year old I have sound but no picture. The lamp is not lighting up. I have already replaced the lamp. After I replaced it, the set worked fine for a couple of hours, but is...
This tv has self diagnostic feature that will show last error through front light blinks, there is procedure to activate and read out error code to diagnose problem section of tv to solve its issue so to get tv back in business.
Let me know to proceed.
Thanks.
Mar 03, 2011 | Mitsubishi WD-60737 60 in. HDTV
Our Mitsubishi DLP WD-60737 is only one month old. As of last night there are solid vertical lines running through the entire set. Please help
Call Mitsubishi and find out who is the closest warranty repair service station in your area, they will take care of this for you.
Sep 04, 2009 | Mitsubishi WD-60737 60 in. HDTV
My check engine light won't go away, keeps saying code 17?
Your engine is staying cool too long/closed loop temp not reached
probably need a new thermostat.
Apr 18, 2009 | 1996 Mitsubishi Eclipse
Mitsubishi WD-60737 TV Logo
46 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
