Question about Garden
Pope whipper snipper starter cord problem
The starter cord on my pope whipper snipper has suddenly stopped pulling further than about 8 inches from it's housing. If i try to get it to move further, the whipper snipper falls over. Any ideas? Thanks
  • sue_yeahyeah
    sue_yeahyeah Feb 20, 2014
    Thank you. This was extremely helpful.
    Problem Solver:
  • 14 Answers
The first thing you need to do is take the recoil cover off. There are several parts to a recoil and one or more parts may be worn and coming out of place then jamming.Replace worn parts if this is the case. If the cord pulls freely when removed then you may have a problem in the engine, try turning the flywheel by hand with the spark plug out. If it does not rotate there is something inside the cylinder or broken in the crankcase. If it is a 4 stroke engine you may have fluid above the piston,you will find this out when you remove the spark plug. drain the fluid from the cylinder and replace the plug you will be good to go. Good luck
Posted on Feb 09, 2014
3 Suggested Answers
evwood
  • 50 Answers
SOURCE: how to pretension starter cord
Remove the housing and pull the cord partly out. Then rewind the rest. Check to see if it retracts properly. Good Luck!
Posted on Jan 03, 2009
evwood
  • 50 Answers
SOURCE: pretensioning starter cord on ryobi whipper snipper.
This was answered in a previous solution
How to change a pull cord on STIHL FS51 whipper snipper
here's a nice vid on the FS55 which may help a little: How to Replace Starter Rope in Stihl FS 55 Trimmer Hunker
Here's another vid of a gas powered weed wacker.
https://www.youtube.com/watch?v=hdtbsjb9saQ
Best wishes.. I hope this is at least a little helpful.
Nov 21, 2017 | Stihl Garden
Victa Tornado Whipper Snipper 2-stroke. Why doesn't it start?
Rebuild or replace the carburetor. Whichever is cheaper and that should solve the problem
Feb 04, 2016 | whipper snipper Garden
My whipper snipper got so hot on the shaft that it melted the new plastic cord holder so I was told the drive shaft cable needed greasing can you tell me how to do this and with what grease
quite likely the head you put on is too heavy for your unit . not sure where you are but any auto parts store should sell grease that will work OK look for one that is a HI temp lube tho .
Aug 09, 2015 | whipper snipper Garden
Sthil whipper snipper fs38 won't engage the starting pull mechanism, it turns but won't grab drive coupling
remove the recoil cover and check the dogs that engauge the starter to the flywheel
Jul 28, 2012 | whipper snipper stihl fs 38
What would have caused my talon whipper snipper to seize?
hello, lack of lubrication will make engine seize up,and also when the trimmer is hung up with the engine down the cylinder will fill up with fuel to where you cant pull rope,found this out myself,hope this helps,,
Feb 20, 2012 | Garden
My 2 stroke whipper snipper won't start
As with all 2 stroke engines,
1. Pump the fuel plug. 3 -5 times.
2. Turn the stop botton onto start.
3. Choke onto hot.
4. Pull the cord . Most important... dont touch the throttle trigger when pulling the cord. Wait until until it starts up.
If you do. (like it says in the instructions, your flooding the engine)
Works every time for me on everyone's whipper snippers.
Feb 09, 2010 | Ryobi Garden
How to pretension starter cord on ryobi whipper snipper
Dec 30, 2008 | Ryobi 15" Electric Factory Reconditioned...
Cord stayes out motor not running
Take it back to place of purchace.
We get these all the time if its the cheap bent sharft with starter between shaft and motor. the easy start spring gets jammed and needs replacing.
Dec 26, 2008 | Garden
Garden Logo
156 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
