Question about Guillemot Thrustmaster 4160545 Ferrari Wireless GT F430 Scuderia Edition Cockpit
Conector Cord broken
Replace a melted Duralit toaster cord that melted from it touching my toaster oven. Need to replace the whole cord. Thanks, Shelley
cut the bad part off the ac cord then use "****" conector to crimp on a new cord. make sure and note the stripe on the cord and that indicates the neutral wire. the stripe is on the outside of the cord on one of the sides. the stripe is molded on to the outside of the wire on one side only
Apr 18, 2011 | Vacuums
Boot up problems, start but will not boot, press power up will not access hd
check the power conector is firmly connected to hdd or change the power conector to another one which is free loose contact in the power wont run the hdd change the ide connector or sata with a new one place ur hand on the hdd and feel wether the hdd is running if not change the power conector still not runnunig change ur hdd to new one also look ide slot in the motherboard and the hdd for bend pin or broken leads
Oct 13, 2010 | Dell Inspiron 6000 Notebook
Amtenna conector problems
Your problem is more than likely due to a bad/broken connection on the inside of the antenna connector. If you're brave, and handy with a soldering iron, you can open the case and check/resolder the two joints at the connector. Otherwise, take it to a local electronics shop. It's a simple repair, but only for those who know their way around inside a scanner.
Bill B
Mar 08, 2010 | Icom IC-R10 Handheld Scanner
Vga conector
there's no problem with the color (black,white,blue) it's doesn't matter.
Dec 17, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Hp 6210 not powering up i have replaced power cord
Dear this problem is not a power cord but chane the power adeptor and open the printer beck side and check the mail conector in printer ............ok
Jul 14, 2009 | HP OfficeJet 6210 All-In-One InkJet...
"No Connection"... My first attempt with HDMI SUUUUCKS- HELP
The connector board inside the tv is the one has circuit traces already broken. there is nothing outside the tv can be done. The HDMI conector is high end technology solder. finally the solution is to replace the conector board inside the tv.
Jan 02, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
TV plug came loose inside tv
The damage most be heavy for the power cord to come out with the conector that attaches to the main board,telling you where it goes will not help because most likely you have a broken main board,you shoud get an estimate from a qualified technician.
Sep 04, 2006 | Philips Magnavox MT1905B 19" TV
Guillemot Thrustmaster 4160545 Ferrari Wireless GT F430 Scuderia Edition Cockpit Logo
24 people viewed this question
Top Guillemot Video Game Consoles & Games Experts
shaun taylor
Jeffrey
Jeffrey
Chris Larocque
Are you a Guillemot Video Game Console and Game Expert? Answer questions, earn points and help others
