Question about 1997 Dodge Ram 3500 Truck Black Grille Grill
Removing dimmer switch - 1997 Dodge Ram 3500 Truck Black Grille Grill
    Genius:
  • 1A Auto Parts Master
  • 2,494 Answers
If it's on the column undo the screws holding the cowling on,you may have to remove the steering wheel ,mark the shaft to wheel so it goes back in the same spot, disconnect air bag fuse if it has one disconnect the plug for wiring then you should be able to see the mount screws to the column.
Posted on Mar 17, 2016
How do I remove the instrument cluster dimmer switch in my 2000 Lincoln town car
Switch - Panel Dimmer
Special Tool(s) syg~tr~en~file=st1445a.gif~gen~ref.gif Radio Removing Tool
T87P-19061-A Removal
  1. Disconnect the battery ground cable
  2. Pull out the radio using Radio Removing Tool.
  3. Remove the radio.
    1. Disconnect the electrical connectors.
    1. Disconnect the antenna cable.
    1. Remove the radio.
    2. Remove the instrument panel finish panel bolts.
    3. Remove the instrument cluster finish panel bolts.
    4. Pull out and position aside the instrument cluster finish panel.
    5. Disconnect the electric clock electrical connector.
    6. Remove the instrument cluster finish panel.
      1. Disconnect the headlight switch electrical connector.
      1. Disconnect the dimmer switch electrical connector.
      1. Remove the instrument cluster finish panel.
      2. Remove the dimmer switch.
        1. Remove the screws.
        1. Remove the dimmer switch.
    7. Installation
      1. NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn the strategy.
        To install, reverse the removal procedure.
Nov 29, 2015 | Lincoln Cars & Trucks
Headlights wont come on but all other lights do
Dimmer switch is on the floor, right? remove dimmer switch and replace with new one. Probably all rusted and corroded inside, you may have blow the brake switch when you hit the dimmer, also check the wiring to both the dimmer and the brake switches.
Mar 04, 2014 | 1975 Cadillac Eldorado
Replace dimmer switch in a wall for light fixture
ok shut off circuit breaker or fuse first.
then remove knob on dimmer.
next remove cover and screws.
then remove mounting screws.
loosen screws holding wires. if one is loose tighten and retry
dimmer and don't forget to shut power off after trying dimmer.
replace by reverse order. Make sure the wires are tightened
securely.
Mar 24, 2013 | Leviton Decora Light Dimmer Switch
Lightolier 3 way remote wiring
If you have determined the wiring to be correct, then yes, the remote is probably defective..
According to Lightolier literature, your Lightolier OS600 is called a "strap dimmer". Having 540W on a 600w rated switch is pretty close to the limit (90%) of the switch, and will cause the switch to fail sooner than say a 300w load. The 600w rating of the switch applies only if all the heating sink fins are in place. Often times, when installing in a box with another switch or dimmer, fins must be removed to allow the switch to physically fit. If any fins are removed, the rating of the switch is reduced. Page 30 of the manual shows that a 600w strap dimmer that has a single fine removed is reduced to a 500w capacity dimmer, and if both fins are removed, it is reduced to a 400w dimmer. You may find that you will need a 1000w dimmer to reliably gain control of your 540w load, as it will control 600w even with both fins removed. This derating is required due to the heat created by the dimmer. Heat is a killer for electronics, and solid state dimmers are no exception.
Check out page 32 of that manual. On it, are wiring diagrams for dimmers and switches. I believe your is figure "G" that shows the 120v "hot" (black) connected to the black wire of ALL switches, the yellow wires of ALL the switches are connected together, but are not connected to anything else, the 120v neutral (white) connects to the MASTER white wire AND light fixture white wire and finally, the MASTER red wire connects to the light fixture black wire.
It is also important to note that these switches are for standard tungsten incandescent and quartz halogen lamps ONLY. They are NOT suitable for CFL, Fluorescent or other types frequently found in commercial / industrial buildings such as neon or other gas lamps such as Metal Halide, Mercury Vapor, High Pressure Sodium, etc.
I hope this helps & good luck!
Jun 01, 2012 | Philips Lightolier Onset 600W Incandescent...
1998 buick century only high beams and turn signals work. No headlights. I have checked breakers, relays,fuses,power at headlight switch, power at headlight harness, all are good.
The Buick Century is equipped with a multi-switch. This switch is an all in one switch that controls your cruise control, windshield wipers and turn signals in one switch. This switch also controls dimming and brightening of your headlights. The dimmer switch is simple to replace, and all you need is a phillips head screwdriver to complete the task.
  1. Removing the Steering Column Shroud
    • Removing the dimmer switch starts at the steering column. To plan this task out, access the steering column by removing the screws holding the steering column shroud in place. This will expose the turn signal lever. Remove the lever by twisting it forward, and pulling it out of the switch.
    Removing the Dimmer Switch
    • The switch is held on by two screws and a wiring harness. The wiring harness can be removed by prying up on the locking tabs and pulling the connector out of the socket. The two screws can be removed with a phillips head screwdriver. The switch will slide out. To install a dimmer switch, be sure to repeat these steps in reverse order.
Oct 09, 2011 | 1998 Buick Century
Can not connect new dimmer.
I think you are removing a 3-way dimmer. Is there another on-off switch that also turns the dimmed light on and off? You will need to replace it with another 3-way dimmer. Here is a link to an excellent how-to write-up.
http://www.ehow.com/how_2280970_wire-threeway-dimmer-switch.html
Jan 27, 2010 | Cooper Industries Cooper Wiring 9534DS...
How to dissable a pre-existing dimmer switch
You don't want to disassemble the dimmer ... you want to remove the dimmer and replace it with a toggle switch
Get a switch at the hardware store or at the big box place. You only need a standard wall toggle switch - color to suit your taste ... gray, ivory, white, brown or red usually. Expect to pay less than $3.00 and maybe as little as 75 cents.
It is simple ...
turn off the power to the light at your circuit panel.
Remove the knob (pull it off) - remove two little screws that hold the cover plate on. There may be a nut under the knob ... remove it (leftie - loosie -- righty - tighty)
Remove the two screws that hold the dimmer in the box,
Pull the dimmer out.
loosen the screws that hold the wires onto the dimmer ... you may have wire nuts holding the wires together. if so, remove them
set the dimmer aside.
you should be working with two black wires in the wall. What ever is attached to the dimmer is the wires you will be using. It does not make any difference which colored wire goes on which brass screw - more below - except the green ... the green goes only on the ground screw.
put one wire from the wall on one brass screw
put the other wire from the wall on the other brass screw.
put the bare wire (or green wire) on the green screw on the switch frame.
arrange the wires behind the switch and screw two screws into the wall box ... make sure the switch is straight.
put the cover on -- two screws ...
turn on the power.
If you have more question, attach to this post.
Thanks for using fixya.com
a
Oct 26, 2009 | Electrical Supplies
I need a pull chain DIMMER switch for my fan light. Only one set of wires supplies the fan and light. Surely SOMEBODY has a pull chain dimmer ??? Thanks. Bill
Bought three fans for the bedrooms, all hunters with pull chain dimmers. Less than one year and two of the three dimmers are shot. Can't find a replacement so I bypassed it. Remove light assembly and unplug 9pin connector. Remove black vented dimmer assembly by removing wire nuts and disconnecting the 2wire connector(black and white wires). Cut the 2wire connector off and save it in case you find a part someday. Wire nut black to black(hot) and white to white(neutral). You will disable the pull chain by wire nutting those two wires together.
Jul 29, 2009 | Hunter Ceiling Fan Light Switch Control
High beam dimmer switch on a 1989 Cadillac Seville
Could be a couple of things. One would be that the dimmer switch has over time come loose and is now out of adjustment. Or the plastic piece in the column that pushes the rod that goes to the switch has broke. Or the switch is bad.
May 19, 2009 | 1989 Cadillac Seville
Need to see diagrams of the figs. 3-6 from a Chilton's manual...
My son came down and figured it out for me. Not sure what all he did but he had to make a few modifications by splicing the wires together after cutting the wires just under the dimmer switch...then a few adjustments were needed to get it to all work right.
Thanks
Jun 06, 2008 | 1992 Pontiac Bonneville
1997 Dodge Ram 3500 Truck Black Grille Grill Logo
20 people viewed this question
Top 1A Auto Parts Vehicle Parts & Accessories Experts
Mike Stager
Mike Stager
Jesse Walters
Jesse Walters
Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
