Question about Philips Magnavox 20MT133S 20" TV
Tv won't turn on manually or with remote.
Tv won't turn on, manually or with remote. Water was spilled in tv.
    New Friend:
Grab a blow dryer and then take of the back of the tv and blow dry it until everything is dry but make sure you don't melt any plastic and if that doesn't work I don't know what to do.
PRAY
Posted on Jul 19, 2015
  • Kristen Jul 19, 2015
    PRAY
    Novelist:
    Champion:
  • 236 Answers
The water shorted out something in the power supply. If it got into the high voltage section, then probably this circuit has shorted.
Stargazer
Posted on Feb 19, 2008
Vivo tv won't turn on lost the remote and the
These are the universal remote control codes to Vivo TV. 0004 0005 0009. Check this link to know more codes and proceedings to other brands of remote controls, and buy one remote control that has setup codes with your TV. The above said codes are for GE remote with Vivo TV.
Jan 23, 2013 | Televison & Video
Tv won't turn on manually or with remote. Just
Take it back end get a different one,
Nov 11, 2012 | Televison & Video
Power button only one that won't turn power on
Have the remote tested either with a tester that most shops have or in a dark room with a digital camera the display will faintly flash when remote pointed at it and buttons pressed.
Also if button does not work (power) unplug the set for a while to see if it will reset. If the tester shows same problem--no working for power or have to press ******* buttons 99% chance something got spilled onto remote and got inside
Oct 24, 2012 | RCA TruFlat 27F520T 27" TV
Won''t turn on the tv also cannot change the settings manually on the tv
Thanks for stopping by.
What is the model number and manufacturer of the TV you are trying to control with the CT-90157 remote?
Not all IR codes are programmed into all remotes.
Sep 26, 2011 | Toshiba CT-90157 Remote Control
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Jun 24, 2011 | Vizio 42 in. LCD TV
I spilled some water on my tv and now the sound is broken
Turn the TV off imediately. Remove the back cover and heat up the wet area with an hair dryer to thoroughly dry the board. Then try tv again.If it doesnt solve the problem look for the board that the speaker wires connect to and replace that board..You should be able to buy online.
Oct 17, 2009 | Insignia IS-LCDTV32 32 in. Television
My philips flat tv keeps on going to the menu screen on its own.
Make sure you do not have a sticky remote. Remove the batteries from the remote and turn it on manually at the TV itself.
If the menu does not come up, your remote has problems. Did you spill anything on it or drop the remote?
other possibility is that you have a neighbor with a similar remote.
Good Luck!
E
Mar 02, 2009 | Philips Televison & Video
Tv broke
Spilling water on a TV voids the warranty. It is not safe to use. Buy a new unit.
Nov 07, 2007 | TruTech PVS2119 19 in. LCD Television
Philips Magnavox 20MT133S 20" TV Logo
168 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
