Question about Panasonic Cell Phones
Pairing bluetooth phone kx-tg7641
Manual lost , need to pair with cell phone
SOURCE: n73 not pairing with visorlite
here's the manufacturer's website where you can download the manual (it is also marketed as Supertooth Light)
http://www.supertooth.net/down_light.html
Posted on Jun 24, 2008
bigbam51
  • 18 Answers
SOURCE: what is the default code to pair a bluetooth with a lgcu920
The Default code for my Lg Vu is 0000 so i assume it shall be the same for yours.
Posted on Jan 28, 2009
SOURCE: Trying to pair omnitech 2.0 bluetooth headset without manual
before attempting to pair your headset with another device, be sure that the bluetooth headset is in the off position
  • press and hold MFB until indicator light flashes blue and red. The headset will also beep twice
  • to pair your device to the bluetooth headset use the bluetooth pairing instructions from you device's instrucition manual.
  • input ID code 0000 when requested by the device
  • the headset and device are paired correctly when the blue and red indicator light flashes blue only.
Any questions email: shyrosi@yahoo.com Subject: omnitech bluetooth
Posted on Mar 09, 2009
trillian_tx
  • 4 Answers
SOURCE: bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Posted on Apr 14, 2009
email4saundr
SOURCE: Talk2 Cellular Innovations Bluetooth HFBLU-FP5.
try all zeros or 123456 whatever will fit in the space provided.
Posted on Dec 12, 2009
Supertooth ce0560
here u go... Settings>Bluetooth>tap bluetooth slider to on> make sure your device u want to pair is on , and wait till they pair up.
Apr 23, 2014 | Cell Phones
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
E52 i want pair with my pc i do not know what is the pair password how to do it please clear
Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Feb 13, 2011 | Nokia BH-104 Bluetooth Headset
Need passkey for the pairing for bluetooth with
The passkey in the Phone prompts up only when you are trying to pair your device to another device,
So, you can provide 1234 as the password and another user who is pairing with you should also provide the same,
Incase if it is not working under Generic key or if you are facing any other problem related to Bluetooth pairing, Please contact your Service Providor and check..
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
Pairing bluetooth with cell phone
try 0000 , thats four zero's as paring password
Jun 07, 2009 | Cell Phones
Bh 101 bluetooth headset lost manual and forgot pairing code
Apr 14, 2009 | Cell Phones
I need a instruction maual for a itrax bluetooth device
Pairing With A Bluetooth Enabled Cell Phone
1. The BTCK06 and the Bluetooth enabled cell phone should be within a distance of 3 feet
(1 metre).
2. With the BTCK06 OFF, press the MULTI-FUNCTION Button (The bottom button) for 6 seconds.
The Red & Blue LED's will flash alternatley and the speaker will make a long BEEP sound.
3. The Bluetooth cell phone will search for nearby Bluetooth devices. The cell phone will display the
BTCK06 in the list of Bluetooth devices. If you are using a "dongle" type Bluetooth adaptor,
follow the manufacturer's instructions for that device.
4. Select BTCK06 to add this Bluetooth device into the list of the paired devices.
5. Enter in the PIN Code "0000" and your mobile phone will show that pairing is complete.
6. If Pairing is successful, user will hear a long BEEP and the Blue LED will flash about every
3 seconds.
Nov 24, 2008 | Cell Phones
Lost manual
Since it was already paired with your cell phone it should show up in your phones bluetooth device list, it should be as easy as navigating to the bluetooth settings in your phone (usually found in tools) and selecting the Voyager 520 and selecting the connect button. Give it a try as I have to reconnect mine periodically also.
Aug 07, 2008 | Plantronics Hama Voyager 520 Bluetooth...
N73 not pairing with visorlite
Mar 13, 2008 | Nokia 6300 Cellular Phone
Cell Phones Logo
46 people viewed this question
Top Panasonic Cell Phones Experts
Rommel Balcita
Andrew Taylor
Andrew Taylor
Are you a Panasonic Cell Phone Expert? Answer questions, earn points and help others
