Windows boot manager boot bcd status 0xc0000225
5 Suggested Answers
ziraffa
  • 827 Answers
SOURCE: Can not start windows
You have incurred damage to the boot sector of the drive. This means you have to re-install the operating system. You'll have to get a hold of a Windows disk, or you can download an .iso (disk image) of Ubuntu linux and burn it (as a disk image/iso) onto a disk. Ubuntu Linux is free.
When you have a disk, start the computer and enter the BIOS.
Many newer computers display a brief screen, usually black and white, with the computer manufacturer's logo during POST.
Entering the designated keystroke will take you into the BIOS Setup. Common keystrokes to enter the BIOS Setup are F1, F2, F10, and Del
In there you have to go to Boot Devices and make sure the first one is CD-ROM so that the computer boots from the disk.
It may be set to this by default.
So, either buy or borrow a Windows disk, or download and create a Linux disk, put it into the computer and install.
Sorry to tell you that you cannot boot your computer :( but now you know you need an Operating System disk to proceed :)
Hope this helps
Chris (ziraffa)
Posted on Jan 02, 2009
haayz
  • 197 Answers
SOURCE: windows boot manager file: /boot/bcd status:
Try check your hard disk with the other machine. Try running hard disk diagnostic test. If there's a problem with diagnostic test i suspect your hard disk is faulty. If you tried connecting with other machine then same problem, suspected also hard disk faulty. You might need to change it.
Posted on Jun 02, 2009
  • 788 Answers
SOURCE: Windows boot manager-hardware failure
Try pressing F-8 and look for last known good working configuration.
If you are trying to reload from CD/DVD drive and it continues to boot into your old windows configuration, Enter your BIOS settings, and change the boot order to CD/DVD and then Hard drive
Posted on Sep 15, 2009
  • 3940 Answers
SOURCE: File: \Boot\BCD Satus: 0xc0000098 Info: The windows
boot to the Windows DVD, select the option to REPAIR, If this is only a software issue, that should resolve.
If it doesn't then run diags on the HDD is it may be failing
Posted on Jan 15, 2011
Hi just got a quick question i have an hp envy 15-u011dx lapotop and i was doing a partition on the hard drive and for some reason when i boot the laptop up i got this error 0xc0000225 what does this
Windows failed to start. A recent hardware or software change might be the cause. To fix the problem:
1. Insert your Windows installation disc and restart your computer.
2. Choose your language settings and then click "next."
3. Click 'repair your computer'.
If you do not have the disc, contact your system administrator or computer manufacturer for assistance.
File: \Boot\BCD
Status: 0xc0000225
Info: An error occured while attempting to read the boot configuration data.
Dec 12, 2014 | HP Computers & Internet
Compaq cq4010f boot error
cindy,way restore what was the problem.
try a factory reset that should help.
Jul 01, 2013 | Compaq CQ4010F Desktop PC (NY650AAABA)
Missing boot manager
To run the Bootrec.exe tool, you must start Windows RE.
To do this, follow these steps:
Put the Windows Vista or Windows 7 installation disc in the disc drive, and then start the computer.
Press a key when you are prompted.
Select a language, a time, a currency, a keyboard or an input method, and then click Next.
Click Repair your computer.
Click the operating system that you want to repair, and then click Next.
In the System Recovery Options dialog box, click Command Prompt.
Type Bootrec.exe, and then press ENTER.
Note To start the computer from the Windows Vista or Windows 7 DVD, the computer must be configured to start from the DVD drive.
For more information about how to configure the computer to start from the DVD drive, see the documentation that is included with the computer or contact the computer manufacturer.
Bootrec.exe options
The Bootrec.exe tool supports the following options. Use the option that is appropriate for your situation.
Note Use the Bootrec.exe tool to troubleshoot "Bootmgr Is Missing" issue.
If rebuilding the BCD does not resolve the startup issue, you can export and delete the BCD, and then run this option again.
By doing this, you make sure that the BCD is completely rebuilt.
To do this, type the following commands at the Windows RE command prompt:
bcdedit /export C:\BCD_Backup
c:
cd boot
attrib bcd -s -h -r
ren c:\boot\bcd bcd.old
bootrec /RebuildBcd
/FixMbr
The /FixMbr option writes a Windows 7 or Windows Vista-compatible MBR to the system partition. This option does not overwrite the existing partition table.
Use this option when you must resolve MBR corruption issues, or when you have to remove non-standard code from the MBR.
/FixBoot
The /FixBoot option writes a new boot sector to the system partition by using a boot sector that is compatible with Windows Vista or Windows 7.
Use this option if one of the following conditions is true.
The boot sector has been replaced with a non-standard Windows Vista or Windows 7 boot sector.
The boot sector is damaged.
An earlier Windows operating system has been installed after Windows Vista or Windows 7 was installed. In this scenario, the computer starts by using Windows NT Loader (NTLDR) instead of Windows Boot Manager (Bootmgr.exe).
/ScanOs
The /ScanOs option scans all disks for installations that are compatible with Windows Vista or Windows 7.
Additionally, this option displays the entries that are currently not in the BCD store.
Use this option when there are Windows Vista or Windows 7 installations that the Boot Manager menu does not list.
/RebuildBcd
The /RebuildBcd option scans all disks for installations that are compatible with Windows Vista or Windows 7.
Additionally, this option lets you select the installations that you want to add to the BCD store.
Use this option when you must completely rebuild the BCD.
hope this helps
Oct 14, 2012 | eMachines El1852g-52w Pentium E5800...
Hi on my pc gt 5404 i got this message " windows boot manager File BOOT BCD STATUS 0xc000000f. what i have to do to insert the windows vista disc i cannt open it .Pleas any suggestions
Make sure your computer boots from the disc drive by going into the bios and assigning it as the first boot device. Then let it load and do a startup repair.
Mar 17, 2011 | Gateway GT5404 PC Desktop
Windows boot manager for TOSHIBA PRO L300
You will need an original windows installation disc and not a recovery disc. If you do not have one, then you have the option of taking to a shop that does and have them run the repair utility. Or, if you can find someone who has burned a copy of the windows ultimate boot disc, that will also help in repairing the boot manager and files.
May 23, 2010 | Toshiba Satellite A135-S4527 Notebook
What is file error 0xc000000e
File: \Boot\BCD
Status: 0xc000000e
Info: An error occurred while attempting to read the boot configuration data.
1. Insert your Windows Installation disc and restart your computer.
2. Choose your language settings and then click "Next"
3. Click "Repair your computer"
If you do not have this disc, contact your system administrator or computer
ERNZ
Feb 03, 2010 | Toshiba Sattelite A105-S2051 Notebook
Windows boot manager file: /boot/bcd status: oxcoooooe9 info: an unexpected I/o error has occurred I am experiencing the same problem on a Dell laptop (Inspiron 1525: Windows boot manager - file:...
May 09, 2009 | Dell Inspiron 1525 Laptop
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
