Question about Kenmore Dishwashers
Kenmore 9744480 Trying to reset the front control panel. I need the correct button sequence
  • 93 Answers
SOURCE: How to reset the control unit?
press heated Dry , Nornal, Heated dry Normal: The machine will go into diagnostic mode. this may reset your control.
If not clear the fault, unplug the power cord,open up the electronic control panel again and check your connection, maybe the wire harness to the drain relay pin is not connected correctly.
Posted on Jul 26, 2008
  • 171 Answers
SOURCE: Front panel on Kenmore Diswasher
Hi jenniferr922,
I'm Harvey the Master plumber.
Your question is: You purchased a white Kenmore dishwasher and you are redoing your kitchen and all of your appliances are Kenmore stainless steel. You were wondering if the front panel was the only replacement or if you needed to order something else for the control panel.
It's your choise. If you like the control panel, keep it. If not, replace it when you replace the white panel.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
SOURCE: Kenmore 665 15899
To reset and run diagnosis on the model 15899100 Kenmore Dishwasher you need to press the following buttons on your front panel. Hi Temp, Air Dry, Hi temp, Air Dry. The sears service technician just left my house and used these codes to reset and run diag on my washer.
Hope this helps
Posted on May 28, 2009
SOURCE: Reset control panel for Whirlpool ADG 4952
whirlpool adg4952m is reading F2 and not working
Posted on Jan 12, 2010
  • 351 Answers
SOURCE: I have a Whirlpool Gold Quietwash Plus (part #
i would cut the power to it for awile 5mi and try it that may do it
Posted on Sep 27, 2010
Self cleaning button sequence want start
you need to see in the bottom of your washer or take the back panel and some of this washers have a reset button, try due that, make sure is unpluged while you due this, clean all the contacts inside and check all the wires make sure they okay
Oct 17, 2012 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Tip
Kenmore Elite & Whirlpool Duet Washer and Dryer Control Panel Locked
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Hopefully, this simple advice will save you an expensive service call.
on Jun 27, 2009 | Kenmore Elite 45986 Front Load Washer
Our Kenmore Elite Dishwasher has a blinking green light next to the clean cycle. It won't reset. We changed the motor and this has been going on ever since. Do you know what we need to do to fix it....
Hello
Blinking green light can be reset by following two buttons in sequence: press HIGH TEMP WASH-HEATED DRY buttons in sequence around 3-4 times so that the control reset itself. Please get back to me if you have any other questions.
Kevin
Nov 11, 2010 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite smartwash and the machine says contols locked, is there any way to reset that?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 25, 2010 | Kenmore Elite 45986 Front Load Washer
CONTROL LOCKED
Press on hold the DRAIN/SPIN button on the front panel for three seconds. The instuctions should be printed directly below the button. This is used to lock and unlock the panel as a safety feature to prevent small children from playing with the buttons. If this does not correct the problem, unplug the washer for AT LEAST 30 minutes to reset the Central Control Unit (CCU). Let me know if this corrects the problem. If you still need assistance, please let me know.
Jan 14, 2009 | Kenmore Elite 45986 Front Load Washer
Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
Jan 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 665 15899
Hope this helps
Jan 05, 2009 | Kenmore 15899 Built-in Dishwasher
Control door lock light stuck 'on'
Unplug it for 40 minutes to reset.
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Dishwashers Logo
75 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
