Question about Epson Expression XP-305 Inkjet Multifunction Printer - Colour - Photo/
Epson XP-305 Printer, power to the printer, but won't switch on. Fuse, cable and plug all checked and are OK.
Printer won't switch on, fuse, lead and plug all check ok. Tested in several working sockets by itself. Other items tried in same sockets,OK.
  • 25 Answers
SOURCE: Epson Stylus CX6600 All in One
I had the same problem that was similar where it would get to 16% of the document and then say that the printer is not responding. I unplugged the USB and plugged it back in and that fixed it, but it did the same thing about a month ago.
Posted on Feb 11, 2009
gwbm
  • 353 Answers
SOURCE: no electric getting to printer although I have
It sounds like you may have a faulty power supply or main board. If you wish to carry out further technical diagnosis, you will need to dismantle the printer. Please let me know if you wish to do this, by making a new post, and I will provide helpful information for this task.
Otherwise, you must take it to a technician for diagnosis and repair.
Posted on Mar 13, 2009
ginko
  • 19396 Answers
SOURCE: R300 Epson Printer No power light
If it does not light up at all , then that means that there is an internal fault or no power is getting to the printer.
Check power cord connection, try unplugging and plugging back. Do this with printer not connected to computer.
If still no luck that there is a broken contact (typically a broken solder joint on printer power socket), or some component had blown inside the printer.
The printer must be taken apart and tested to fix the problem.
Posted on Apr 10, 2009
abrahambaby
  • 182 Answers
SOURCE: no pwr to printer.plug fuse and cable ok. epsom dx5050
if their is no power ckeck your power outlet with any currnet meter to check the voltage is avalible to operate the printer is avalible change the plug cable and try again or try with any other cable avalible check the power switch of the cable if nothing happen better to contact your service center
Posted on Oct 18, 2009
aicaxz
  • 511 Answers
SOURCE: DX5050 epson printer.printer won't come on when swtched on.
Try to check the switch button at front panel board. And mounted fuse and printer main board.
Posted on Oct 19, 2009
Where are the fuses located
Yes I think there may well be an internal fuse. I suggest you do a search on YouTube, they are pretty good at fault finding vids.
Hope this helps
Regards
Sep 30, 2014 | Epson Office Equipment & Supplies
How do I access the fuse on an Epson R290?
Open the case. Check with Board. There might be a fuse near the power inlet lead.
Aug 17, 2014 | Epson Stylus R290 InkJet Printer
Printer won't turn on...is plugged in and has been printing well.
hi, have you tried checking, changing the fuse in the plug.
check the lead is fitted correct.
as for the fuse is the printer running of mains lead or just of the usb lead let me know, if its mains the unplug the lead that goes to your comp and then try it with just the power lead plugged in to see if that makes the differance.
Check the mains lead works try it on something else if you can if its running off only the usb lead then the lead may be at fault.
Let me know then i can assist you further ok
Nov 06, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I have changed my fuse but still have no green light on my printer
ALL LIGHTS ARE OFF -
PRESS THE POWER BUTTON TO MAKE SURE THE PRINTER IS ON
TURN OFF THE PRINTER AND MAKE SURE THE POWER CORD IS SECURELY PLUGGED IN
MAKE SURE YOUR OUTLET WORKS AND AS NOT FUSED OR IS NOT CONTROLLED BY A WALL SWITCH OR TIMER.
TRY PLUGGING THE POWER LEAD INTO ANOTHER SOCKET
YOU COULD HAVE A FAULTY LEAD
Nov 03, 2009 | Epson Stylus R265 InkJet Photo Printer
Just wont switch on - I checked the fuse in the
Try to use different cable. you may want to check below link for any other Canon MP830 issue
http://pc-and-peripheral.blogspot.com/
Oct 19, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Oct 18, 2009 | Epson Stylus DX5050 All-In-One InkJet...
No pwr to printer.plug fuse and cable ok. epsom dx5050
I have epson stylus printer dx8400 wont switch is a fuse in side
Yes probaby, ut wiggle power cables first , then try new power cable
Apr 23, 2009 | Epson Stylus DX8400 All-In-One InkJet...
Laserjet 2100 Won't turn on!
Yep, the power cable can be faulty, test a different one on a different socket. Try also playing with the power connector on the printer.
If the power cable is fused, like for example in UK, then check the fuse.
If it still does not give any sign of life, then there is a fault on the power supply board, inside the printer, usually the power supply fuse. Part is about $45 refurbished/$55 original .
If the problem is not the fuse you will need to get a technician testing on board component, and probably replacing a faulty resistor or capacitor.
Sep 26, 2008 | HP LaserJet 2100 Printer
Epson lq 2180
-check the power cable
-check on of switch
-check the fuse
-replace the power board
Aug 18, 2008 | Epson LQ-2180 Dot Matrix Printer
Epson Expression XP-305 Inkjet Multifunction Printer - Colour - Photo/ Logo
77 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
