Question about Whirlpool WED7500VW Laundry : Dryers
Clothes are damp after cycle is completed - Whirlpool WED7500VW Laundry : Dryers
4 Suggested Answers
SolutionGuy
  • 331 Answers
SOURCE: Problem drying clothes
This is the classic symptom of "poor air flow". Another symptom you didn't mention (but I bet is happening) is that the top of the dryer gets VERY hot. OK, don't move your dryer yet... get a flashlight and look behind there. See the flexible vent connecting the dryer to the wall? It must have SMOOTH, FLOWING turns. No crushing allowed. If it's crushed/pinched, you found the problem. It's "choking" off the air flow... not allowing the hot air to escape and containing all of it in the dryer cabinet. If this is the problem, pull the dryer away from the wall about 8" and make sure the vent isn't pinched off anymore. Leave your dryer this far out, it'll ensure that this doesn't happen again. If the flexible vent is OK, there is a blockage in your house's internal dryer duct work somewhere. Turn the dryer on and go outside to where the exhaust is. Check air flow. Check the exhaust vent for debris (I've seen birds build nests in the outside exhaust, incubates the eggs...but your clothes won't get dry!). If your dryer location and the exhaust location are quite a distance (20' or more) from each other, you should hire a professional to come out and thoroughly clean it out for you. In this case, you should have this done once a year as part of routine Home maintenance. To test and verify my solution to this, you can remove the dryer vent from the wall and cover the end of it with a pair of old pantie hose. Then run the dryer as usual (the pantie hose will act as a secondary lint trap). You'll see that the dryer will be happy again and the clothes will dry in no time at all.
Posted on Aug 21, 2007
hunter19_46m
  • 7482 Answers
SOURCE: clothes are still damp at end of cycle
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to
locate the air duct going from the blower to the drum. Normally inside the air duct you will find
the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove
the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it
is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing
the two wires and taping them together with electrical tape. If the coil heats up then replace
the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause
a fire, as you have removed the safety of overheat from the machine. I will include these two web
sites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck, Hope this helps
Please do not forget to rate me, Thank you
Posted on May 27, 2010
Testimonial: "Very fast response....Thank you so much!"
  • 272 Answers
SOURCE: My dryer leaves the clothing
Greetings,
here is a quick way to see if its your dryer or vent...disconnect the vent from behind dryer and let blow without being hooked up. Now, wash some clothes and using caution not to overload the dryer and check it again after a normal dry cycle. if ok , the vent is blocked somewhere from dryer to outside vent. if still not working with vent disconnected. There is a problem with dryer...you will most likely find a blocked vent.....Bruce Denton...if I'm correct, please advise if your satisfied...thank you
Posted on Jan 05, 2011
Why are my cloths warm but slightly damp at the completion of all cycles selected.
Good Afternoon Friend,
I understand that your Frigidaire dryer is leaving your clothes warm but slightly damp. I will be more than happy to assist you. So I am able to better assist, I kindly ask that you provide me with the model number of your dryer. Typically, this number is located on the back of the door, or possibly around the edges where the door meets your appliance. Looking forward to hearing from you.
-WP-
Jul 09, 2014 | Frigidaire Dryers
Dryer is set to run 40 mins when it shouts off at 0 on the dryer is has only run 20 mins according to my stove timer
Dryer has a moisture sensor that detects the clothes are dry so it shuts off earlier. If the clothes are still damp then the dryer vent may be plugged and causing the unit to run hot or not able to fully evacuate the air from the machine. Clean the vent and make sure it's completely free and try again. If it short cycles again and clothes still damp you may have a sensor controller issue.
Jun 16, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
Hotpoint vbsr3100boww washer
check your pump filter. this is the usual problem
Mar 24, 2014 | GE Washing Machines
No heat when drying cloths
Check the vent that goes outside it may be blocked.
Jul 23, 2010 | Maytag Neptune MDG9700A Gas Dryer
Dryer turns on and rotates. However, does not dry clothes completely. Cycle signals wet,then damp,cool down and finally dry,but clothes are still wet. Sometimes the dryer works fine and completely dries...
This problem may be the result of a dirty lent filter which if clogged will short cycle the dryer and the clothes will still be damp when done. Also a dirty exhaust pipe (usally 4") will prevent the clothes from drying correctly. Make sure that the air is leaving the machine. To do this you have to go outside when the machine is running.
Mar 21, 2010 | Kenmore Dryers
Condensor tumble dryer not drying clothes
Give the correct model number in full. It will be near the serial number. Engineers plan projects and drive trains!
May 25, 2009 | Dryers
Spin cycle not removing enough water from clothes
your manual states that it can be caused by cold rinses and or spin cycle not getting completed. please try to rinse in hot or warm and see if that does not solve your problem
Dec 20, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Nov 09, 2007 | Admiral AAV7000A
Whirlpool WED7500VW Laundry : Dryers Logo
23 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
