Carrier 38yxa part diagram
Outside unit is not running. Can I reset?
  • 18 Answers
SOURCE: Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
Posted on Dec 11, 2008
manhandy
  • 146 Answers
SOURCE: my carrier 38BRC024310 is not running outside.
some do have one, but i would check if you have burnt out fuse should be right next to the unite or a blown circuit breaker
Posted on Jun 24, 2009
siyarirash
SOURCE: Carrier outside unit isn't running.
check you can move by your hand without swiching on your a/c.I mean motor should be rotate freely.if so problem with capacitor.you can replace it.but its stucked.better to replace new motor.so it should be done by experienced technician.its around 300 dhr.
Posted on Jul 11, 2009
  • 29 Answers
SOURCE: Outside unit runs continuously, even when system is off.
On A/C units, there is a low voltage line that leads to a contactor, which engages to close the high voltage circuit to the condensor unit. Over time, the accual contacts in the contactor can weld themselves together. Try shutting off your furnace breaker but leaving on the one for the outside condensor unit. If it still runs, your contactor probably needs replaced. Contact a licensed electrician or HVAC contractor and tell them you think your contactor is in need of replacement. Is a fairly simple and quick replace, but the contactor itself is not cheap.
Posted on Oct 10, 2009
SOURCE: carrier ac unit hc39ge237a, is there a reset
Is this a Central Air System?
Posted on Jun 15, 2010
I need wire diagram for 40AQ030300BB carrier unit
you have 24 volt across both terminals of contactor coil? if not and condenser is still running then you have a stuck contactor. also this is a heat pump so you have 24v and common going to out side unit and rodents or dogs may have chewed up wire and causing a short making connection and this would have blew transformer. FYI installing a 3 amp car fuse(spade type) installed in line of 24v coming off transformer will protect transformer as well as other components. your T-Stat may be defective as well.
Jun 27, 2014 | Carrier Heating & Cooling
Carrier Air conditioners
change filter and clean outside unit with water. pull the outside fuze before cleaning.
Jul 29, 2012 | Heating & Cooling
My carrier 38BRC024310 is not running outside. Fan is not running nor compressor. is their a reset switch?
Jun 23, 2009 | Carrier 38CKC042 Air Conditioner
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
System Malfunction, No communication with outside unit
I work on Carrier Infiity systems. The outside board has a Model plug on it. This tells the system what size unit it is. They do go bad. You can reset your self by turning the power off to the Air Handler. These system have 10 year warranty and if you still have a problem have the replace the outside control board and model plug. Also you can contact Carrier on the their website and get answers. You may need to talk to a service rep in your area. Carrier is good about their Tech support. You should have to pay for a service call if you your problem continues. Sometimes power surges or stoem cause these problems but not often Rusty
Apr 26, 2009 | Heating & Cooling
Carrier PTAC Condenser ices over.
You are describing normal operation for a heat pump unit.
Feb 20, 2009 | Carrier 52CQ315 Air Conditioner
Jul 19, 2008 | Carrier 36KCARMS Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
